J1 Tranny 5th pops out
Old May 6, 2008 | 12:34 PM
snapon's Avatar
Default J1 Tranny 5th pops out
I have a 90 crx with a b16 swap and a j1 transmmision when i put it in 5th after 30 seconds it comes out of gear. what could that be
Old May 6, 2008 | 01:05 PM
Malgerus's Avatar
Default Re: J1 Tranny 5th pops out (snapon)
A few things:
Incorrect shift linkage - ie it's not the right length
Worn motor mounts jerking the engine back and forth
Clutch cable incorrectly adjusted - should only be a few millimetres of play on the clutch arm, not completely tight
Or, your synchros/sleeves are worn out inside the tranny. If so, contact GearSpeed for a rebuild kit. I had my synchros done and they work perfectly. But I didn't replace the sleeves.
Old May 6, 2008 | 01:21 PM
zrickety's Avatar
Default Re: J1 Tranny 5th pops out (Malgerus)
check the oil level. when i bought my car the tranny had NO oil in it...barely a drop. and it popped out of 5th all the time. drove it from ohio to new york like that and found the problem later. added oil and it hasn't popped out since
Old May 6, 2008 | 02:31 PM
crxfreak1117's Avatar
Default Re: J1 Tranny 5th pops out (zrickety)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">check the oil level. when i bought my car the tranny had NO oil in it...barely a drop. and it popped out of 5th all the time. drove it from ohio to new york like that and found the problem later. added oil and it hasn't popped out since </TD></TR></TABLE>
x2
this happened to me recently also..same j1 tranny only 5th gear went and topped off the tranny fluid and works like new so that would be what i would check first
Old May 7, 2008 | 04:54 PM
Malgerus's Avatar
Good call, I just assumed that his fluid level was fine
delsol revolution
May 2, 2007 08:08 PM
VtecDA9
Nov 22, 2006 08:14 AM
HBK
13
Sep 17, 2006 11:26 AM
HBK
Sep 15, 2006 02:47 PM
fastlimegreencivic
Feb 20, 2006 05:05 PM
