Car not starting! MYSTERY
Old May 6, 2008 | 09:19 AM
OogalyDoogaly's Avatar
Default Car not starting! MYSTERY
My car was working perfectly fine yesterday, only a CEL code of 61, primary oxygen sensor. That CEL light has been on for a month or so with no problems. Just today, the car won't even turn over. I checked the fuses, tested the spark plugs, jump start the battery, and I hear the fuel pump click with the key in the ON position. It's a 2000 civic si with 77,000 miles on it. Any opinions?
UPDATE- Problem solved, it was a bad main relay
Modified by OogalyDoogaly at 5:11 PM 5/25/2008
Old May 6, 2008 | 09:34 AM
Cooper50290's Avatar
Default Re: Car not starting! MYSTERY (OogalyDoogaly)
You need a new starter for sure same thing happened to my 88 thunderbird. Tell if thats the problem. I would like to know . Thanks
Old May 6, 2008 | 09:44 AM
Default Re: Car not starting! MYSTERY (Cooper50290)
Is there a way to test the starter?
Old May 6, 2008 | 09:59 AM
v!taminb16's Avatar
i went throught this same problem i did everything you did and some more it's your starter
Old May 6, 2008 | 10:05 AM
2mansi's Avatar
Check the clutch pedal sensor. Its a little round sensor on the pedal fork next to the actual pedal. This same thing happened to my friend and we went for days tearing apart the car trying to figure out what was wrong with it. If need be you can use a paper clip to rig the sensor because its $45 from the dealer.
If you have more questions ask someone who knows about alarms. They do the same thing when putting remote start on 5 speed cars.
Old May 6, 2008 | 10:07 AM
EM1adobogirl's Avatar
I kinda had this problem with my SI. My wires just wasn't getting any contact with the battery, thats all.
Old May 6, 2008 | 10:11 AM
Default Re: Car not starting! MYSTERY (EM1adobogirl)
I heard that if I remove my starter autozone or pepboys can test it for me, is that true? I tried resetting the ECU and cleaning the battery terminals as well.
Old May 6, 2008 | 10:26 AM
v!taminb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OogalyDoogaly &raquo;</TD></TR><TR><TD CLASS="quote">I heard that if I remove my starter autozone or pepboys can test it for me, is that true? I tried resetting the ECU and cleaning the battery terminals as well.</TD></TR></TABLE>
taking your starter to autozone would be the best bet and check your ground's
Old May 7, 2008 | 08:11 AM
Default Re: Car not starting! MYSTERY (v!taminb16)
I took my old starter to autozone, they hooked it up to the machine and said they weren't getting a response from my starter so I bought a new one. I put the new one in and still the car doesn't start.... help?!?!?!
Old May 7, 2008 | 09:50 AM
ttt
Old May 7, 2008 | 11:49 AM
I just removed the fuel injectors, they inside looks clean but outside there is gunk. When I try to turn the car on, I can see spits of gasoline coming out of all 4 injectors, but no start. im going crazy!!!
Old May 7, 2008 | 12:01 PM
starting cylonodes
Old May 7, 2008 | 12:09 PM
Default Re: (Cooper50290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cooper50290 &raquo;</TD></TR><TR><TD CLASS="quote">starting cylonodes</TD></TR></TABLE>
Old May 7, 2008 | 12:19 PM
**** nvm that only on my ford thunderbird
Old May 7, 2008 | 12:58 PM
Pro_14481's Avatar
? idk i have the same problem but its a ford lol
Old May 7, 2008 | 02:08 PM
jdeemseerx's Avatar
so whats happening, is it cranking and not starting or is it not cranking at all? like stated earlier, check connections on the battery and all grounds..
Old May 7, 2008 | 02:09 PM
Default Re: (jdeemseerx)
It's cranking but not starting, I already checked the wires and battery terminals. Just to make sure, how many and where are the grounded wires that I should check
Old May 7, 2008 | 02:19 PM
wonder squirrel's Avatar
Default Re: (OogalyDoogaly)
Are you getting spark?
Old May 7, 2008 | 02:24 PM
MrXclusivE's Avatar
there is another sensor on your intake, check the wires on that one.
did you change o2 sensor?
Old May 7, 2008 | 02:26 PM
MrXclusivE's Avatar
Default Re: (wonder squirrel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wonder squirrel &raquo;</TD></TR><TR><TD CLASS="quote">Are you getting spark?</TD></TR></TABLE>
+1
Old May 7, 2008 | 04:30 PM
Yep, I pulled all 4 spark plugs out to test them and they worked. I'm going to try changing the fuel filter, I haven't changed the fuel filter since I first got my car (4 years ago or 50,000 miles ago) I was told that the fuel injectors are suppose to spray out fuel as the car is cranking; but when I took them out today, they were just spitting tiny drops of gas.
Old May 7, 2008 | 07:00 PM
Man this is pissing me off sorry i wish i knew wat was wrong with car
Old May 20, 2008 | 07:22 AM
EquipedWithVtec's Avatar
yeah im kinda having the same problems i bought my car at 89K miles its now at 95K its hard to start like it cranks and cranks then i stop and try it again and it just keeps cranking usually 3rd time trying to start it starts after a crank or 2 but i mean this has to get me to school mon-fri which is 30 miles away lol so i need to find out whats wrong asap.
Old May 20, 2008 | 07:47 AM
grandtheftlunchbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cooper50290 &raquo;</TD></TR><TR><TD CLASS="quote">You need a new starter for sure same thing happened to my 88 thunderbird. Tell if thats the problem. I would like to know . Thanks</TD></TR></TABLE>
things like this **** ME OFF. you cant fix the problem without correctly diagnosing it first! don't come to h-t and start telling everyone what their problem is when you have NO IDEA.
anyways, check to see if you have power to the starter, and have a friend check to see if the solenoid gets power while you turn the key to the start position. if it does, double check that the battery isn't bad, NAPA will test it and charge it for free. if nothing is wrong with the battery and the starter gets power, THEN you're probably having starter issues.
Old May 20, 2008 | 12:59 PM
jdeemseerx's Avatar
Default Re: Car not starting! MYSTERY (grandtheftlunchbox)
First of all, YOU have no idea what you are talking about and your post makes no sense.. so dont pretend like you do NOOB. Secondly, if you READ the post you would know that he already replaced his starter and he is having a CRANK but NO START issue.. meaning the starter is working. Dont use honda-tech as an escape from the real world, having E-***** means nothing 'round here.
How exactly did you test for spark? If you believe it is a fuel problem, you can get starter fluid from any part store.. Take off your intake tube from the throttle body, have someone slightly press on the gas to open the throttle body and spray the fluid into it.. (stand a couple feet away) If it starts, do yourself a favor and buy a fuel pressure gauge, it will help you further diagnose the problem.
