What PRIMER? car is black and going to champ. white????
Old May 6, 2008 | 07:30 AM
aznlaoboi315's Avatar
Default What PRIMER? car is black and going to champ. white????
Okay so my project car is a Granada Black GSR and I'm respraying the entire car with championship white base coat/clear paint system. The car was painted over and its not the OEM paint so what primer would/should I use to cover the black and prevent my base from lifting because I think they painted this car with enamel because you can smell it when you sand past the clear.....
Old May 6, 2008 | 08:20 AM
DDEVIANT1's Avatar
Default Re: What PRIMER? car is black and going to champ. white???? (aznlaoboi315)
I would personally sand the whole refinish spray job off first...that way you know what you are dealing with...either way I would use a good primer sealer( K36 from PPG is a good one) I would tint it white obviously that way you will get better coverage from your paint system, and with less coats.
joeshmo
Oct 17, 2011 06:05 PM
Costco
Feb 14, 2011 09:17 PM
wrh61
Paint and Body
Oct 20, 2008 09:47 PM
redrusch
Paint and Body
Aug 29, 2007 08:03 AM
ybbo
Aug 2, 2007 07:02 PM
