Piston Hone-Which Type is the best for Honda's?
Old May 6, 2008 | 07:22 AM
emotionisdead's Avatar
Very Emergency!!
Default Piston Hone-Which Type is the best for Honda's?
Hey guys, I am going to re-buld my GSR motor and I was wondering what you guys used to hone the cylinder walls with? There is the stone type or the "dingleball" type.
Any help would much appreciated. I was thinking about getting this one from Summit:
Or should I get this one:
Old May 6, 2008 | 07:46 AM
Armed Ferret's Avatar
Default Re: Piston Hone-Which Type is the best for Honda's? (emotionisdead)
uh....you aren't planning on honing by hand, are you?
Old May 6, 2008 | 07:54 AM
Very Emergency!!
Default Re: Piston Hone-Which Type is the best for Honda's? (Armed Ferret)
Do you mean literally by hand, no drill. Or doing it with a drill and not a machine?
Old May 6, 2008 | 08:40 AM
i meant attempting to hone it with anything other than the appropriate machinery.
which doesn't include a drill press or, most definitely, a hand drill.
does the phrase "out of round" mean anything to you?
Old May 6, 2008 | 08:56 AM
Rocket's Avatar
Niether.
Get the Omniman DVD and you will be enlightened.
Old May 6, 2008 | 09:09 AM
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armed Ferret &raquo;</TD></TR><TR><TD CLASS="quote">i meant attempting to hone it with anything other than the appropriate machinery.
does the phrase "out of round" mean anything to you? </TD></TR></TABLE>
Yes "out of round" does mean something. Exactly that. The cylinder is not a true circle. I would be able to tell this by taking a bore micrometer and comparing the two measurements. If it is "out of round," looks like a machine shop is gonna be increasing the bore diameter for me.
Thanks for the input and honest advice.
Old May 6, 2008 | 10:52 AM
4g hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">Niether.
Get the Omniman DVD and you will be enlightened.</TD></TR></TABLE>
i love that video. what ever happened to that motor,how long did it last? those was some high rpms
Old May 6, 2008 | 01:01 PM
Combustion Contraption's Avatar
The stone type is really just a glaze breaker. The other one is, well, a hone. There is some power to be had in correct cylinder wall prep. Whether this would really benefit the average street rebuild, I dont know. If there is still decent crosshatch on the walls, I wouldnt touch them.
Old May 6, 2008 | 02:06 PM
Very Emergency!!
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">The stone type is really just a glaze breaker. The other one is, well, a hone. There is some power to be had in correct cylinder wall prep. Whether this would really benefit the average street rebuild, I dont know. If there is still decent crosshatch on the walls, I wouldnt touch them. </TD></TR></TABLE>
Thanks for the insight!! Very Helpful. I guess I'll know when I take the engine apart.
So if there is a "glaze" of sorts, have it honed?
Old May 6, 2008 | 02:19 PM
lohatch's Avatar
if you are going to run a forged piston you will require more P-to-W than the OEM piston. in which case you will want to have someone with a bore gauge and a nice 4-pt hone, like a sunnen. hone finish depends on ring manufacturer and engine builder preference.
Old May 6, 2008 | 02:28 PM
Very Emergency!!
Default Re: Piston Hone-Which Type is the best for Honda's? (lohatch)
I'm gonna run CTR piston's with Hasting's rings. Maybe I should call them up and see what they recommend!
Old May 7, 2008 | 12:58 PM
lohatch's Avatar
they will probably recommend a 280 grit finish. a lot of the modern ring packs on forged pistons seem to get 280 with a 400 or 600 plateau finish.
Old May 7, 2008 | 02:06 PM
Another thing to keep in mind is that finish hone and ring type determine "break-in" or if there is any.
YOU HERE ME BOI!!!
I couldnt resist.
Old May 7, 2008 | 03:08 PM
Very Emergency!!
I've actually taken everybody's sound advice and I'm just gonna have a machine shop do it for me. They are already gonna mount the pistons on the rods so I might as well have they "mic" the bore and hone if needed.
Old May 7, 2008 | 03:09 PM
Have a Sam Adams.
Old May 7, 2008 | 03:17 PM
4g hatch's Avatar
BUD ICE!!!! for me. u here me boi
itr1235
Mar 2, 2010 07:23 PM
emotionisdead
May 6, 2008 10:46 AM
vtecturboteg22
Apr 25, 2004 04:51 PM
