need help with tdc p1399 200 prelude v-tec (base)
Old May 6, 2008 | 02:40 AM
richmatth's Avatar
Default need help with dtc p1399 2000 prelude v-tec (base)
timing was done about 118000th .problem started at 122,000th checked to see if it was off, dead on. top dead and crank shaft sensor for resistins both are 2.2ohs. telling me i have misfires on 1&2. new plugs wires dis cap and rouder. system gives me ok on short trips but trips engen light on long trips. can hear it stumble only if on gas lighty about 2000rpms in 234 gear. can this be a from a bas short in the ecm,altinater, volt regulater,ignition coil....ect? need a little help has anyone had this problem. looked for this code in the book ,nothing there. found it in a accord book is this p1399 related. has a smell like a new cat could this be the egr
Modified by richmatth at 9:42 AM 5/7/2008
Modified by richmatth at 9:46 AM 5/7/2008
Modified by richmatth at 5:47 PM 5/7/2008
v8assasin
May 12, 2013 06:06 PM
Mr. Chavez
Dec 4, 2008 08:31 PM
bukfuddie
Apr 16, 2006 12:49 PM
yOnKiNaToR
Jan 22, 2004 06:12 PM
