Engine assemble question (poor mans r)
Old May 6, 2008 | 12:43 AM
zacatkings's Avatar
Default Engine assemble question (poor mans r)
i am putting together a b18c block and a b16 head together. The block is fully rebuilt with jdm type r pistons.
my questions are;
what head studs do i order?
what timing belt do i get?
thanks in advance for your info
Old May 6, 2008 | 06:43 AM
geebs's Avatar
Default Re: Engine assemble question (zacatkings)
use the head studs for the head youre using.. so b16a head studs will work..
for the timing belt.. use the type r or gsr timing belt matched with a type r or gsr water pump.. dohc vtec belt with dohc vtec water pump.. use the b18c belt tho.. its slightly longer than the b16a belt because of the block deck height.
Old May 6, 2008 | 06:49 AM
Tuner Eddy's Avatar
^^ great info. always wondered the same thing.
Old May 6, 2008 | 06:51 AM
BrothaSit's Avatar
b16a head studs are too short i use gsr/type r head studs from arp and a gsr timing belt
dc4b20
Jul 9, 2009 09:28 PM
2wheelhunter
Dec 28, 2008 10:37 PM
P12 EG6
Oct 5, 2007 09:44 PM
BoRiCuA
Apr 11, 2006 04:13 AM
blownsi
Oct 6, 2001 07:59 AM
