question about d16y7/y8 vtec conversion
i have a 98 civic hatch dx with a d16y7 engine and i am looking to do a vtec head conversion using a y8 head. i already have the complete d16y8 engine/ecu with a bad block. the y8 is out of a 2000 civic ex. All i need to know if do i need a kit like the LS/vtec to make it work? and do i need to do some kind of work to mate the y7 block/y8 head? what im trying to say is that will the y8 head slap right onto the y7 block without any special tuning? i believe the y7 engine has a higher compression ratio than the y8 so i think having a y7/vtec should have more potential than a d16y8. i know this may be a stupid question but im new at these things and i need help. thanks
There is no such thing as stupid a question. As for the mini-me-vtec conversion I believe you don't need a kit like the Ls-vtec to make it work cause i never did on mine and its running good if not then
so the y8 head will mate with the y7 block with no modifying? basically plug and play style right? but what about the obd-2b and obd-2a thing? will i need any aftermarkets adapter or anything? and about the throttle cable, will the y7 throttle cable work for the y8 intake manifold?
