Higher idle with headlights on
Old May 5, 2008 | 08:39 PM
tpot90's Avatar
Default Higher idle with headlights on
For some reason, I've found that the idle will jump & keep its idle a little above normal when I turn the headlights on. Nothing TOO noticible, but its there.
This also happens when I have heat on.
Can someone tell me why this is? It doesn't really affect any performance, I'm just curious to find why the lights affect the RPMs.
Old May 5, 2008 | 09:00 PM
afreeclimber's Avatar
Default Re: Higher idle with headlights on (tpot90)
your charging system is failing under the load of your headlights, so the pcm tells the rpms to ramp up so the alternator will run faster.
check your battery and alternator for proper function.
Old May 5, 2008 | 09:11 PM
tpot90's Avatar
Default Re: Higher idle with headlights on (afreeclimber)
If my charging system such as the alt/bat fails, will my battery light turn on?
Modified by tpot90 at 10:19 PM 5/5/2008
Old May 7, 2008 | 08:37 AM
professorman's Avatar
humm... My car does this as well. How do you check the charging system? I always thought mine was good.
Old May 7, 2008 | 02:05 PM
disastar's Avatar
This is normal behavior. The headlights are a large current draw and your charging system needs to ramp up output to supply the lights, which you see as a small increase in your idle speed. I'm not sure that you would see a similar increase when you turn the heat on, unless you're in defrost mode which turns on the A/C.
Old May 7, 2008 | 07:16 PM
SOHCMAN's Avatar
Default Re: Higher idle with headlights on (disastar)
Right, under normal conditions, your ECU will signal your IACV to raise your idle when operating requirements dictate. This is most noticable when you do thinks like turn on your AC or sometimes even when electrics are turned on or the steering wheel is turned while parked. some of these things may simply be the engine idling faster from changing mechanical drag (like the power steering)?
In any case I wouldn't be worried unless it bogs and/or dies, indicating a too low idle or a problem with your IACV or ECU...
sohc
itslogz
May 11, 2009 01:10 AM
dylokjai
Jul 28, 2008 12:12 PM
jnet
Oct 30, 2004 03:01 PM
F120man
15
Dec 22, 2003 06:57 AM
AGPSuperstar
Feb 7, 2003 10:17 AM
