FS: 1996 GSR head. Mild port work, ITR intake valves, needs rockers
Old May 5, 2008 | 08:17 PM
Hybrid96EK's Avatar
Default FS: 1996 GSR head. Mild port work, ITR intake valves, needs rockers
I have a 1996 GSR head for sale. Unknown mileage. I JUST put in new valve stem seals on all 16 valves (OEM Honda seals) and did mild ITR style blending on the bowls on the intake side. After the work I had a professional valvejob done and installed ITR intake valves as well. Head is fairly cleaned, was painted by myself. Has EXHAUST SIDE ROCKER damage on the Vtec lobes only. LMA's are still in good shape, all bearing caps are included. Will NOT come with Vtec solenoid or dist or valve cover. Does NOT have cam cap bolts either. Its the head, hot tanked and cleaned, ITR intake valves, fresh valve stem seals and blend, GSR valve springs, assembled. Needs rockers on exhaust side once again. Seals perfectly (leak down tested prior to removal) and has NO other issues. The head has not been cleaned in these pictures. It will be cleaned before its sold. I would prefer local pickup in the Sacramento area. Open to all reasonable offers...
Old May 6, 2008 | 04:02 AM
Hybrid96EK's Avatar
Default Re: FS: 1996 GSR head. Mild port work, ITR intake valves, needs rockers (Hybrid96EK)
Back up...
Old May 8, 2008 | 07:35 AM
Hybrid96EK's Avatar
Bump. Still for Sale.
DRtools
24
Mar 15, 2009 10:32 AM
overrev130
Nov 15, 2006 07:58 PM
nfn15037
Aug 28, 2006 06:05 PM
navin
Aug 22, 2004 04:38 PM
