1st Gen B16 in CRX Si HEEELLPPP!!!
Old May 5, 2008 | 05:59 PM
Serrano44's Avatar
Default 1st Gen B16 in CRX Si HEEELLPPP!!!
I have a 1st gen B16 in a 89 CRX Si. I beleive it has the wrong distributor. Its of a 90 LS integra. its held on with one bolt and its causing a leak. Can anyone tell me the distributor that i need for this engine and also what is the right set up as far as OBD I, II etc and which ECU. Sorry i just baught the car and it seems like the previous owner was a little shady!! Thanks
Old May 5, 2008 | 06:26 PM
traxxasx's Avatar
Default Re: 1st Gen B16 in CRX Si HEEELLPPP!!! (Serrano44)
you need the del sol dohc vtec dizzy.
Your obd-0 unless your converted to obd-1.
if your obd-0 you can use chipped p28 or the original ecu pr3.
Old May 5, 2008 | 06:32 PM
Crx Jimmy's Avatar
Default Re: 1st Gen B16 in CRX Si HEEELLPPP!!! (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">you need the del sol dohc vtec dizzy.
if your obd-0 you can use chipped p28 or the original ecu pr3.</TD></TR></TABLE>
WTF?^^^
you need a obdo b16 dizzy if you are obdo and running the pr3 or pw0
if converted to obd1 you need a obd1 b16 delsol dizzy or a 94-95 gsr dizzy and most likely have a p28
so help us out and figure out what you have so we can help you better
Old May 5, 2008 | 07:08 PM
zrickety's Avatar
Default Re: 1st Gen B16 in CRX Si HEEELLPPP!!! (Crx Jimmy)
if it's the 90 integra dizzy, you are obd0. you need an obd0 b16 dizzy. there are new ones on ebay, used ones on this site. i have the integra dizzy with 2 bolts, 1 using a simple bracket i made and no leaks for 2 years. i'm saving up for the right dizzy
Old May 5, 2008 | 07:11 PM
Hybridize's Avatar
Default Re: 1st Gen B16 in CRX Si HEEELLPPP!!! (zrickety)
If your only issue is the oil leak a new dizzy won't help you. Cam seal leaks are a more than common problem for 1st gen 16's.
Old May 6, 2008 | 04:31 AM
Serrano44's Avatar
How do I know what ECU i'm Running is there a way to open it and tell at the same time id like to know if its chipped how can i tell that. Thanks for all ya'lls help
Ef4doorwagon
Feb 6, 2015 02:14 AM
fatbois88ef
Dec 4, 2011 02:23 PM
Mugencrxsir1
Jul 28, 2010 12:09 PM
border919
Sep 25, 2008 05:46 PM
SuperRacerTypeR
13
Oct 5, 2005 07:48 AM
