Rough idle, but no error codes
Old May 5, 2008 | 03:52 PM
gshock's Avatar
Default Rough idle, but no error codes
2000 Accord SE, 4 cyl. 2.3 VTEC. I've got just under 120k miles and it seems to be idling rough. But no error codes or check engine light. I replaced a very dirty air filter, and put new Bosch OEM plugs in. It seems a little better, but still a little rough. Could the rough idle be an indication of clogged injectors, or a bad air flow sensor? Also, 750 seems low to me. Shouldn't it be 850-1000 rpms? Could there be a problem even if the CEL doesn't come on? Heavy highway driving (60+ miles per day)since January, mostly city driving for a year prior to that.
I used to have a palm pilot that had software for a VW to read EC's. Is there something equivalent for a Honda? I still have the cable with an OBD II connector.
Thanks,
-gshock
Old May 5, 2008 | 04:05 PM
TheMuffinMan's Avatar
He knows where you live!
750/800 is avg
Just use the screw on top of the TB and open it up a bit more, it'll raise your idle - but don't go to extremes, just adjust it a little bit
Old May 5, 2008 | 05:16 PM
hondadude's Avatar
Default Re: Rough idle, but no error codes (gshock)
AutoTap, Auterra, and AutoEnginuity offer palm based systems, I have the original version of Auterra. It works okay for basics, but I also got a Genisys
Here's a link for you ;
http://www.troublecodes.net/te...shtml
As far as your rough idle, try cleaning the throttle plate area with a toothbrush and Berrymans B-12, also spray out the screen on the IACV.
Old May 14, 2008 | 08:43 AM
gshock's Avatar
Default Re: Rough idle, but no error codes (hondadude)
Does anyone know if there are any software tools like this that work on Open Source platforms?
I'm tinkering with swapping my PC over to Linux, but not if I can't run diag. software.
TIA,
-gshock
Dragon760
Mar 13, 2014 04:15 PM
travie_vtec
25
Feb 8, 2013 09:43 PM
pfsmith99
Oct 14, 2012 09:02 AM
jrhcivak
Mar 29, 2012 08:48 AM
92bseries
Dec 7, 2011 12:59 PM
