Will 15x7 +15 fit?
Old May 5, 2008 | 03:33 PM
ef9robert's Avatar
Default Will 15x7 +15 fit?
Quick question, looking at a set of 15x7 +15 was wondering if they would fit. Also they are 4x114.3 could i re-drill them or should i get some adapter?
Thanks.
Old May 5, 2008 | 03:45 PM
my91tealhb's Avatar
Default Re: Will 15x7 +15 fit? (ef9robert)
You will definately have to roll your fenders & run 195/45/15's if you want to slam it. It may still rub but, there was one guy one here that had some sportmax with +15 offset and he was slammed. Re-drill is probably better than adapters. Im not positive but I think adapters will push the wheels out even further.
Old May 5, 2008 | 05:17 PM
mannyman2's Avatar
Default Re: Will 15x7 +15 fit? (my91tealhb)
yeah with adapters it will be close to 0 offset. But if will sticl out a ways... 25 offset would be at the limit. Hope u have some cmaber kits, becasue u will need some negetive camber
Old May 6, 2008 | 09:59 AM
ef9robert's Avatar
Default Re: Will 15x7 +15 fit? (mannyman2)
so would i need camber kit for the front only or for both front and rear?
Old May 6, 2008 | 04:45 PM
r.wright's Avatar
smallest tires possible in order for you to tuck will be a must like 165/50-15 or like suggested above : 195/45
negative camber all around but test it w/ natural camber first as u adjust your coilovers lower..... removal of front plastics, rolling rear fenders and rolling up of inner metal brackets will be a must ..
what chassis do you have?
pandagarage.com offers the hubcentric 15mm 4x100to4x114 adapters and ebay usually has the 25mm ones that are just universal. both of those will bring your offset down to zero or negative 10
wheelchoice had some for 10mm
remember that the smaller adapters like 15mm and below will most likely require you to shave your studs
Old May 6, 2008 | 06:41 PM
ef9robert's Avatar
Default Re: Will 15x7 +15 fit? (Opossum Jenkins)
hmm i only see 20mm and 25mm :-(
Old May 6, 2008 | 10:24 PM
r.wright's Avatar
where? links?
http://pandagarage.com/Interior/wheel%20spacer.htm
those top ones are 15mm..i know it for a fact cus a couple of my friends bought them
Old May 7, 2008 | 01:05 AM
89hatcher's Avatar
i think the smallest tire you can run is a 165/40/15 its going to be streched
Old May 7, 2008 | 06:15 AM
ef9robert's Avatar
Kwel deal, i will give panda a call so i can order a set. Thanks again man!
Old May 7, 2008 | 11:16 AM
nsxtasy's Avatar
H-T Order of Merit
What are your plans for these wheels?
If it's for street use, that width AND the re-drilling are both VERY BAD IDEAS AND UNSAFE. For an EF, get some 15x6 wheels (there are lots of 'em since they fit Civics and Integras) and put 195/50-15 tires on them.
If it's because you're building a show car, or you're making a track rat, different story...
Old May 7, 2008 | 05:30 PM
ef9robert's Avatar
Default Re: Will 15x7 +15 fit? (nsxtasy)
so driving daily on the fwy would be a bad idea?
Old May 7, 2008 | 06:04 PM
89hatcher's Avatar
depending oh the conditions of your roads...if its all smooth and no pot holes...i say go for it and get the low pro tire for it.
Modified by 89hatcher at 7:29 PM 5/7/2008
Old May 7, 2008 | 09:38 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9robert &raquo;</TD></TR><TR><TD CLASS="quote">so driving daily on the fwy would be a bad idea?</TD></TR></TABLE>
YES.
Get some wheels with the right bolt pattern for your car. Don't get wheels with the wrong bolt pattern and then re-drill them; that's making one mistake, and then trying to undo it by making a second mistake.
gordon_nelson
Honda Civic (2001 - 2005)
10
Jul 15, 2013 01:38 PM
muddmonky
Suspension & Brakes
Dec 3, 2012 07:36 PM
em2crusin
Apr 10, 2012 03:24 PM
the all out kid
Suspension & Brakes
Jan 31, 2009 10:07 AM
awalp
Nov 22, 2006 09:35 AM
