tires 4 civic si rims
Old May 5, 2008 | 01:39 PM
Milab21's Avatar
Default tires 4 civic si rims
what is the widest tire size you can put on civic si rims? im gonna get the rt615 or the kdws and was thinking of doing 205/50R15 if that will work?
Old May 5, 2008 | 06:59 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tires 4 civic si rims (Milab21)
205/50-15 is fine. So is 195/55-15.
If you want a really sticky tire on dry pavement, then get the Falken Azenis RT-615 in 205/50-15. Another excellent choice, even better than the Azenis, is the Dunlop Direzza Sport Z1 Star Spec in 195/55-15.
I don't know if you're referring to the KDW or the KDWS. The KDW/KDW2 is really overpriced and you can do a lot better for the money. If you're considering the KDW2 because you want better traction in rain and/or longer treadlife, then you may as well get the Kumho SPT. Its performance is very similar and you can get the SPT for only around $44/tire in 195/55-15 at tires-easy.com, which is about a third the price of the KDW2.
The KDWS is an all-season tire and it doesn't make sense to get an all-season tire in your case. Unless you plan to use these on snow, in which case you may as well get the all-season Kumho ASX for half the price.
Old May 6, 2008 | 04:05 PM
Milab21's Avatar
Default Re: tires 4 civic si rims (nsxtasy)
thanks for your help, im gonna go with the falkens
SlowEJ8
Jul 21, 2009 01:25 PM
RomesEM1
Jul 2, 2009 09:31 PM
zoso
21
Aug 16, 2007 04:39 PM
zad5
Aug 31, 2006 08:08 AM
EJ8VTEC
Dec 21, 2005 06:33 AM
