1997 Honda accord window moving up slowly
Old May 5, 2008 | 12:13 PM
buzzmeok's Avatar
Default 1997 Honda accord window moving up slowly
I have a honda 1997 and the driver side window move up very slowly. I put some vaseline and it works great. In about to weeks it goes back to moving up and down very slow. The motor was removed and lubed and the channel has been cleaned. I allso tryed Motor oil and white grease. any special grease i should use. I have all so removed the motor and tryed to lift up the glass with out the motor and its very hard to move, until I put some vaseline and then it works great until
to or for weeks latter . any thing I might be missing ? Any special grease? or maybe the rubber is going bad ( no cracks in the rubber an it shows no wear look new )
Modified by buzzmeok at 1:19 PM 5/5/2008
Old May 5, 2008 | 12:28 PM
fatman69's Avatar
Default Re: 1997 Honda accord window moving up slowly (buzzmeok)
yea my 97 dose the same thing but wht i noticed when i give it sum gas it go's up normal
Old May 5, 2008 | 01:00 PM
Turbowa's Avatar
Default Re: 1997 Honda accord window moving up slowly (fatman69)
If its hard to move the window up and down with out the motor attached to the glass, then it will prob. need a new window run channle. That is the part that you keep lubbing up.
Old May 7, 2008 | 08:22 PM
brose's Avatar
Assuming the PW motor is ok, you may also consider a defective PW regulator. I had identical symptoms on my '96, and replacing the regulator fixed the problem. Relatively easy to replace/install.
Old May 7, 2008 | 08:39 PM
blanktape's Avatar
I have a 95 accord and both front windows were extremely slow, my driver side even stop working and stuck in winter. What i did was use silicon lubricant to clean up the rail. I take apart the door panel to reach inside the track and give it a real good cleaning. Now it works fine but eventually it will get dirty again so regular maintenance on the rails will be recommended. Hope my tips will help.
fuzzysig
Sep 21, 2017 11:13 AM
d_EG COUPE
May 15, 2008 05:49 PM
mbeckwit
May 3, 2008 07:25 AM
bjrta
Aug 7, 2006 07:20 AM
95Prelude
Jun 14, 2003 12:08 PM
