500whp too much for Crower Econo-Billet rods?
I didn't know I would be pushing for this power level when I started or I would have used a rod with a higher hp rating. Does anyone have experience with these rods @ this hp level?
I have a 92 hatch, fully built H22 with a GT30, Blitz sbc (has progressive boost).
I typically run 13 psi (350whp) and sometimes bump it to 17 (435whp).
I am considering a GT35 to use lower boost levels for the same power and wondering about raising the higher boost level to 500 whp. Car is street driven only. I've had this setup for 2 yrs. and around 10K miles. Ran 19 psi (465whp) for 5-6K mi.
I have no experience with these rods, but there is no set whp breaking point, where if you pass it, they will break. Either way though, as long as the tune is good, I dont see a problem with them handling another 35whp.
H22, GT30 w .82, Darton sleeves, Arias 10:1 pistons, STR 70mm TB, Golden Eagle intake, new stock cams and crank (polished), JG ported head, AEM can gears, Crower econo billet rods, Moroso aluminum pan, ProDrive oil pump gears, 1000 cc injectors, AEM fuel rail and regulator, MSD Digital 6 ignition and HVC coil, RevHard exh. man., Precision/Garret GT30 w .82, Tial 46mm wastegate, Blitz SBC-ID boost controller, Walbro 255 fuel pump, Fluidyne radiator, Hondata S300, Tilton twin disc clutch/fwhl set, intercooler, turbo timer, cooling mist methanol injection, etc.
tuned on Mustang and DynoJet dynos, producing within 15 hp of each other.
Around 350whp @ 13psi & 465whp @ 18psi on 120 race gas.
Retuned to 435whp on E85 @ around 17 psi.
Modified by purpleh22 at 3:51 PM 5/5/2008
you spent a boat load of cash on the engine/turbo setup and you put in "econo" connecting rods......hmmmmm......well i guess they will work. if you look at the machining/forging of those rods they do look similar to eagle H beams which have been proven to take over 500whp on many setups.
the only reason crower underrates their "econo" rods is so it wont take away the sales from their "premium" forged rods. if they claimed the econo rods to handle the same power (or close) to the premium rods everyone would buy the cheaper rod and save 300 bucks. so they low ball the "power" to scare people away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 »</TD></TR><TR><TD CLASS="quote">H22, GT30 w .82, Darton sleeves, Arias 10:1 pistons, STR 70mm TB, Golden Eagle intake, new stock cams and crank (polished), JG ported head, AEM can gears, Crower econo billet rods, Moroso aluminum pan, ProDrive oil pump gears, 1000 cc injectors, AEM fuel rail and regulator, MSD Digital 6 ignition and HVC coil, RevHard exh. man., Precision/Garret GT30 w .82, Tial 46mm wastegate, Blitz SBC-ID boost controller, Walbro 255 fuel pump, Fluidyne radiator, Hondata S300, Tilton twin disc clutch/fwhl set, intercooler, turbo timer, cooling mist methanol injection, etc.
Modified by purpleh22 at 3:51 PM 5/5/2008</TD></TR></TABLE>
I'm curious. Why sleeve that motor for those power levels? Especially since it's a closed-deck block?
Stock sleeves are made of a material (FMR?)that is not very compatable with forged pistons. Mahle makes a Gold Series piston that is supposedly workable. They were new when I was building the engine and I didn't want to worry about how well they actually worked.
I also think that later H22 bolcks are open (97-98?) Mine is the earlier closed deck though.
I have the same concern.
Right now I have a set of both crower and eagle h-beam rods, I'm going for a power range of 650 to 700, the thing is I don't know which ones to use.
I have ask around and the input ppl have given me is to go with the crowers because the eagle h-bean stretch at those type of number.
So from some of the replys I have read here it seems the crower is the way to go.
What do yo think?
What do yo think?
I would think that if they are good billets, they would be stronger than Eagle forged rods. I had them magnafluxed anyway because the econobillets are made outside the US and I wanted to be sure they weren't flawed. Crower does all the final machining but I had it all double checked by a good race shop machinist.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20luda »</TD></TR><TR><TD CLASS="quote">i'd think they would be ok, whats you're setup? just curious im a gt30R h22a owner as well
350whp at 13psi... Mustang dyno?</TD></TR></TABLE>
holy smokes, I got 366whp at 12psi on my china t3\t4!
As for the topic, rods on these setups seldom fail due to raw power, they actually fail due to rpm, so you may want to consider how high you are going to rev before worrying about it. If you are on a stock h series tranny, I wouldnt advise going over 7500 at any power level in which case the rods in my opinion will be just fine.
350whp at 13psi... Mustang dyno?</TD></TR></TABLE>holy smokes, I got 366whp at 12psi on my china t3\t4!
My setup is making increasing power @ 7500 and does not fall off until 8 k or so. Had the trans rebuilt before the engine and turbo work. In 2 years and 10K no probs. yet, but it's street driven only.
Why would the stock Prelude tranny make a difference?
H series trannies hate R's over 7500 trust me... they will handle all of the power you can throw at them, but be careful with the revs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 »</TD></TR><TR><TD CLASS="quote">I didn't know I would be pushing for this power level when I started or I would have used a rod with a higher hp rating. Does anyone have experience with these rods @ this hp level?
why do you need 500 hp in a FWD STREET DRIVEN vehicle?
Usually run it on low boost setting @ around 350whp. Occasionally run on higher boost for fun. Had quite a bit of experience with built cars and bikes. Although not as fast as some that I've owned, it's quick and a rush.
I get too addicted to the power, I stay at peak power all the time, i cannot turn anything down, thats why I overbuild things and tune well on pump gas hehe
Why do I need 500 hp for the street?
Think of it as a quest - you'll figure it out!
We live in a time when 'stock' bikes are turning 9 sec. 1/4s
'Stock' cars come from manufacturers with 400, 500, 650 and even 1000hp.
I'm just trying not to fall too far behind!
THIS IS CROWERS IMPORT TECH.DECIDED TO COME ON HERE TO SEE WHAT PEOPLE HAVE TO SAY ABOUT OR PRODUCTS.EITHER PEOPLE KNOW THE TRUTH OR SAYING ONLY WHAT THEY HEAR WHEN NEVER USED ANYTHING FROM US.HAVE ANY QUESTIONS ON THE FAST TIME RODS OR ANYTHING ELSE JUST EMAIL ME HERE OR AT IMPORTTECH@CROWER.COM
OR ROBERT@CROWER.COM
AND ILL DROP YOU SOME INFO
Ok. What about Crower econo billet vs. Eagle forged? Would the Econo-billets be stronger than a forged rod like the eagles? Is a billet rod typically stronger than a forged rod?
Modified by purpleh22 at 8:38 AM 5/16/2008
this is crower here.on this site to see whos a bullshitter.for the guy from toronto where are you getting your information from??you say crower does this and sais but you have no idea what your talking about.unless you to directly to us i would best say think before you speak
Just viewed a Crower add stating that their Econo billet rods are good for 650 flywheel hp. That would be over 550 whp.
