ATTN: B Series Transimission Help:!!!!!!!!! No 2nd gear or Reverse
Old May 4, 2008 | 06:55 PM
Quickridez_3's Avatar
Default ATTN: B Series Transimission Help:!!!!!!!!! No 2nd gear or Reverse
i have a turboed type r and the tranny is like new never had the 3rd gear honda grind or anything. After i got off the freeway i went to hit 2nd gear and i had no 2nd what so ever and i also dont have reverse. there was no sign of anything going out it just went. does anyone know what broke internally or what i need to fix it
Old May 4, 2008 | 08:49 PM
p10hlm's Avatar
Default Re: ATTN: B Series Transimission Help:!!!!!!!!! No 2nd gear or Reverse (Quickridez_3)
take it apart and go from there
Old May 5, 2008 | 11:21 AM
havok hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickridez_3 &raquo;</TD></TR><TR><TD CLASS="quote">i have a turboed type r and the tranny is like new never had the 3rd gear honda grind or anything. After i got off the freeway i went to hit 2nd gear and i had no 2nd what so ever and i also dont have reverse. there was no sign of anything going out it just went. does anyone know what broke internally or what i need to fix it </TD></TR></TABLE>
My guess would be something is up with the shift linkage.. . Or you bent a shift fork inside the tranny from a HARD shift.
Can you get the car into 2nd or reverse with the engine off? IF so .. then I would say its inside the tranny...
Old May 5, 2008 | 10:13 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
wierd...if you have two issues on separate forks...i would say your change/selector mechanism is busted somehow. the tabs that move the forks do bend and break. or it's like someone mentioned, shift linkage...how does it feel when you shift into these gears with the motor off? if you don't feel it clicking in at all, it's probably what i mentioned. inside the transmission.
stevevang
Apr 14, 2014 02:47 PM
Quickridez_3
May 4, 2008 08:08 PM
USDM-EK4*
Jun 5, 2007 09:33 PM
Luchini
Jan 13, 2004 12:32 AM
