B&M Oil Cooler Kit
Back in 2004 I purchased a B&M oil cooler kit that included the radiator, hoses, and all the fittings/adaptors to relocate my oil filter on my 99 4cyl coupe. I'm 99 percent certain that I only paid about $80 for it from one of the mass auto sites (jegs, summit, jcw), but I'm not sure which one.
That car was totaled, and I couldn't get the kit off of it, and now I'm looking for another one. The only comparable kit I can find is the B&M 70296 Hi-tek kit, but at ~$280, I can't believe it's the same one. Anyone have info on a cooler/relocator kit that's not so much?
EDIT: link to the kit I referenced above for $280.
B&M Hi-Tek Engine Oil Cooler Kit
Might you be looking for this guy?
http://store.summitracing.com/...w=sku
That's the one I'll be running on my 94 EX Automatic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Honda_Guy »</TD></TR><TR><TD CLASS="quote">Might you be looking for this guy?
That's the one I'll be running on my 94 EX Automatic.</TD></TR></TABLE>
dont think so since he mentioned it also relocated his oil filter.
Keep in mind with that kit you'll still need an adapter plate mounted between your oil filter and block to reroute the oil to and from the cooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">dont think so since he mentioned it also relocated his oil filter.
Keep in mind with that kit you'll still need an adapter plate mounted between your oil filter and block to reroute the oil to and from the cooler.</TD></TR></TABLE>
Right, but if you look closely in the link I posted...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B&M »</TD></TR><TR><TD CLASS="quote">-This kit is designed to remotely mount the oil filter and includes an adapter to mount to the engine block
-CNC billet machined engine oil filter diverter
-CNC machined billet filter relocation adapter
-Includes braided steel lines and fittings </TD></TR></TABLE>
