Ctr cams in b16??? what should i expect
I have a b16a and i am putting ctr cams valve spring and retainers the head has only been milled 8 thousands(.008) and a s2 intake manifold i am worried about the timing should it be affect? so here are a couple Q's
Q 1. Should milling the head .008 do anything with timming?
Q 2. Do i need to get anything to help my build?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moddedmuskegon »</TD></TR><TR><TD CLASS="quote">alright thanks i hope crome will be enough for this but, until i run crome will my p73 run it fine and i shouldnt have a problem with anything else right?
Thanks Fat chick magnet</TD></TR></TABLE>
Yeah running a stock P73 ECU should be fine, but you will be wasting a bit more gas.. a friend of mine is running a 1997 jdm P73 ecu in his b16a2 with CTR cams and It's running very good. And tuning on crome is good I'm personally going to be tuned on crome myself.
you can also make more power if you look into buying some cam gears and having the tuner mess around with them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moddedmuskegon »</TD></TR><TR><TD CLASS="quote">so the head being milled .008 isnt a big deal everyone said im going to have to retard or advance my timing or something that was my man concern</TD></TR></TABLE>
retarding or advancing it shouldnt be hard...just mess with your dizzy while using a timing gun....
If you read your manual I believe it can tolerate up to a .15" thou, mill on the stock cam gears without correction so you'd be fine with only .08". That being said, I would invest in a set of adjustable cams gears to get the most power out of that setup though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">If you read your manual I believe it can tolerate up to a .15" thou, mill on the stock cam gears without correction so you'd be fine with only .08". That being said, I would invest in a set of adjustable cams gears to get the most power out of that setup though.</TD></TR></TABLE>
what he said
So i should slightly retard or advanced the timing? (if needed)
You only need to set your ignition timing as normal. You adjust your cam gears, not for correction, but for best power on the dyno.
ok guys i put the cams in might see a differnce not sure though from 3-6rpm ish its doggie then v-tec kicks and it fells pretty good i think maybe timing but could be something else? Would you guys do any thing with adjustibles cam gears ive heard Advancing exh. +1 or 2 degrees but then ive heard retard intake so what do you guys think?
Modified by moddedmuskegon at 8:32 PM 5/9/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moddedmuskegon »</TD></TR><TR><TD CLASS="quote">ok guys i put the cams in might see a differnce not sure though from 3-6rpm ish its doggie then v-tec kicks and it fells pretty good i think maybe timing but could be something else? Would you guys do any thing with adjustibles cam gears ive heard Advancing exh. +1 or 2 degrees but then ive heard retard intake so what do you guys think?
Modified by moddedmuskegon at 8:32 PM 5/9/2008</TD></TR></TABLE>
for better results get it tuned....dont want to mess with timing alot if you dont really know what you are doing...but with nothing aftermarket internally it should run pretty smooth....im running a poorman's type r and it ran pretty good...but my crank pulley was loose and threw off my timing...so waiting for a new crank pulley to come in..
JohnnieChimpo
Mar 14, 2005 10:29 PM
crxh22project
Feb 25, 2005 04:17 AM
