PWR Radiator cap?????
Old May 4, 2008 | 06:43 PM
Bigblockhatch's Avatar
Default PWR Radiator cap?????
I have a eg PWR radiator.I cant find a replacement cap.Anyone know which ones will fit.The factory honda one will not.
Old May 5, 2008 | 08:24 AM
R.S.AKIMOTO's Avatar
* B A N N E D *
Default Re: PWR Radiator cap????? (Bigblockhatch)
STANT mini-cap
Used for motorcylcle applications. If I can find the part# I'll post it later. Should be able to find it at your local NAPA!
Old May 5, 2008 | 08:28 AM
TheWickedOne's Avatar
Default Re: PWR Radiator cap????? (R.S.AKIMOTO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO &raquo;</TD></TR><TR><TD CLASS="quote">STANT mini-cap
Used for motorcylcle applications. If I can find the part# I'll post it later. Should be able to find it at your local NAPA! </TD></TR></TABLE>
Yup!.. i found the replacement caps at Advanced Auto. Just bring it with you to match it up should be a 15psi cap.
Old May 5, 2008 | 09:59 AM
FRernesto's Avatar
That's funny I just ran across the same thing with the radiator cap the other day. Napa is where I got it from in just one day no special order needed.
Part # Pressure
10361 (19-21 pounds)
10362 (22-24 pounds)
Old May 5, 2008 | 10:04 AM
PHDZINE's Avatar
Default Re: (FRernesto)
I also lost mine and I just used the NISMO one from my 240SX
Old May 5, 2008 | 11:15 AM
Default Re: (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">I also lost mine and I just used the NISMO one from my 240SX</TD></TR></TABLE>
Is it me or the caps with the valve relief do not actually relieve pressure from the coolant system ? seems like more of a way to "lock" the cap then actually serve the purpose of relieving the pressure..
also, its wise to either purchase a spare petcock or get ready to drill and tap to a standard size as the bung has a proprietory thread/pitch that NOBODY has.. the plastic will strip out over time..
Old May 5, 2008 | 03:50 PM
BIGTUNA's Avatar
Default Re: (TheWickedOne)
98 Toyota Camry V6 cap.
Old May 6, 2008 | 03:22 AM
taggart_lumpy's Avatar
have a skunk2 nissan one on ours
Old May 6, 2008 | 05:36 PM
Default Re: (taggart_lumpy)
Thanks guys....
coot_er
Dec 18, 2006 07:50 PM
EJ1 wilcox
Nov 20, 2006 02:46 PM
marshun
Mar 18, 2005 09:48 AM
spunky424
13
Aug 26, 2004 03:08 PM
ATS*Mark
Feb 8, 2004 07:13 PM
