Front sway bar bushings?
Old May 4, 2008 | 06:18 PM
H22PreludePhil's Avatar
Default Front sway bar bushings?
Has anyone replaced the front sway bar bushings?Mine look a little worn and i was wondering if just replacing the bushings would help the car handle better.
I know alot of people remove the bar totaly and most people beef up the rear bar on a front wheel drive car for better handling.I guess my real question is whats better.Improving the stock bushings on the oem bar or just removing it totally?
Thanks
Old May 4, 2008 | 07:30 PM
94vtirozguy's Avatar
replace them with some poly bushes if they are worn
Old May 4, 2008 | 08:09 PM
Hawkze_2.3's Avatar
Default Re: Front sway bar bushings? (H22PreludePhil)
Yessir, I would either replace the bushings with some poly or remove the front bar. Having those mushy, damaged bushings just makes the car more sluggish in the turns.
Old May 5, 2008 | 02:58 PM
slamdlude's Avatar
Default Re: Front sway bar bushings? (Hawkze_2.3)
Autozone sells poly ones in the ricer section.
Old May 5, 2008 | 04:36 PM
Default Re: Front sway bar bushings? (slamdlude)
Oh thanks, you must have been down that aisle to know J/K.
Thanks for the replies
Old May 5, 2008 | 05:47 PM
E-Money's Avatar
replace them with oem rubber, while your at it do the endlinks
Old May 6, 2008 | 02:20 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Yessir, I would either replace the bushings with some poly or remove the front bar. Having those mushy, damaged bushings just makes the car more sluggish in the turns.</TD></TR></TABLE>
Do you want poly inserts up front ? Wouldnt that stiffen the front up more, like same idea as adding a stiffer(thicker) front sway bar but obviously to a much lesser extent ?
Old May 6, 2008 | 03:05 PM
Hawkze_2.3's Avatar
Default Re: Front sway bar bushings? (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">
Do you want poly inserts up front ? Wouldnt that stiffen the front up more, like same idea as adding a stiffer(thicker) front sway bar but obviously to a much lesser extent ? </TD></TR></TABLE>
I doubt it will be noticable when compared to some new OEM bushings. All the bushings are supposed to do is let the swaybar rotate as freely as possible, I can't see how them being stiff would affect the ride quality at all.
You could probably use some metal bushings that do not flex at all and you wouldn't notice a difference just because of how the swaybar works.
Old May 6, 2008 | 03:12 PM
lude98SH's Avatar
ok gotcha
mrboompow
Feb 24, 2014 06:25 AM
dgerej2
Suspension & Brakes
May 21, 2010 05:55 AM
96romaEK
Suspension & Brakes
26
Apr 16, 2010 03:25 PM
dtran002
Nov 6, 2007 05:51 PM
amej8
Apr 18, 2007 02:25 PM
