Need advice on IAC custom placement. No room for it at this stage. Pics inside.
Old May 4, 2008 | 05:33 PM
Mikey3000's Avatar
Default Need advice on IAC custom placement. No room for it at this stage. Pics inside.
With my STR intake manifold my IAC is up in the brake lines. The pictures I have here are when the motor was mounted with old HASPORT mounts. I moved my motor back about 1" to get better axle angle and made my own custom mounts which is why i'm having this problem now. So what should I do? Rerouting the brake lines seems to be the most difficult and time consuming solution. Can I mount the IAC remotely or drill holes maybe on the bottom of the manifold? What would the Fab genious' of H-T do?
Old May 4, 2008 | 05:59 PM
snootworks's Avatar
Default Re: Need advice on IAC custom placement. No room for it at this stage. Pics inside. (Mikey3000)
http://www.t1raceparts.com/pro...c.htm
Although I'm sure you can make something similar yourself. Tony's stuff is pretty though.
Old May 4, 2008 | 06:48 PM
m R g S r's Avatar
Going the t1 adapter route would be a lot easier than plugging the current spot and re drilling/tapping a new hole for the IAC on the top of the IM.....
Old May 4, 2008 | 08:31 PM
mrbsponge's Avatar
im gonna throw my opinion out there for ya.
i have an AIR/carbon manifold and at the time there was no aicv adapter, i run 1600cc injectors and my iacv is just tucked back behind the intake manifold with NO water lines hooked to it. car idles great!
really what im getting at is if you have a good engine management, its not needed and can get away with great idle characteristics. what are you using?
Old May 5, 2008 | 02:45 AM
Mikey3000's Avatar
Default Re: (mrbsponge)
i was thinking about not using it and hoped it could idle ok w/o one. i will be using 1600 cc injectors and i use Hondata S300.
Old May 5, 2008 | 05:24 AM
thermal's Avatar
I've fabricated one before.... similar to Tony's dapter flange for remote mounting on custom ITB set-up. Works great!
Old May 5, 2008 | 09:03 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">im gonna throw my opinion out there for ya.
I was going to suggest no IAC but he seemed set on using one......
Old May 6, 2008 | 04:13 AM
Mikey3000's Avatar
Default Re: (m R g S r)
i decided to block it off. thats the laziest way out of it.
Old May 6, 2008 | 12:00 PM
manifoldmiketyson's Avatar
Default Re: (Mikey3000)
depending on your engine managment you can always use an iac like the one offered through electromotive
http://www.electromotive-inc.com/sensors.html
Old May 6, 2008 | 02:43 PM
Mikey3000's Avatar
Default Re: (manifoldmiketyson)
oh wow thats good stuff. thanks.
Old May 6, 2008 | 04:04 PM
Boner_Ben's Avatar
I have 1600's, S300, and no IAC and my car idles pretty decent.
Old May 6, 2008 | 04:50 PM
Mikey3000's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">I have 1600's, S300, and no IAC and my car idles pretty decent. </TD></TR></TABLE>
good to know, thanks for letting me know!
K2sInteg98
Jan 29, 2013 06:49 AM
cantaffordaccord
Welding / Fabrication
Mar 4, 2010 12:40 PM
patastinky
12
May 3, 2006 10:22 PM
SpoonSleeper
Oct 11, 2005 12:39 AM
redboost10
Feb 15, 2005 11:57 PM
