ignition timing/ tune ?s
Old May 4, 2008 | 03:57 PM
DarKStaR5's Avatar
Default ignition timing/ tune ?s
I have a gsr bottom end with 82mm 12:1cr pistons with b16 head, gsr cams, rest of the head is stock. It will be done at the end of this week, and my question is this. I have read that the "JUN" and "mugen" chipped ecus add alot of timing. I have ran my "jun" chipped computer on a few different stock motors and have done fine, but now that im getting into more compression im worried about it being to much until i can get it tuned. Any was i can retard the distributor to compinsate for it? Or should i get my buddy to put a chrome basemap on it? If so which map P30 or P72? Any help is appreciated, trying to learn about this. Thanks
Modified by DarKStaR5 at 1:11 AM 5/5/2008
Old May 4, 2008 | 08:30 PM
phearable's Avatar
Default Re: ignition timing/ tune ?s (DarKStaR5)
Retarding your distributor timing to 12 deg btdc should be enough until you get the setup tuned. Just run premium 91-93 oct & listen for knocking until you get tuned or get your self a better basemap.
Otherwise, you may want to consider using a basemap from a simular build. Your base ignition timing, engine management system choice & more are major factors to consider when playing with ignition timing.
If your not planning on having the setup tuned, you should consider a wideband oxygen sensor system such as the innovate lc-1 db gauge system & possibly a tunable engine management system such as hondata s300 etc
Old May 5, 2008 | 01:51 PM
DarKStaR5's Avatar
Default Re: ignition timing/ tune ?s (phearable)
I will be running 93oct, if i set it to 12 deg btdc, does this mean i need to take it easy? I was really wanting to put some cams in before i got it tuned.
So would i be better off putting a p30 or p72 basemap on, or finding someone with a setup similar and maybe getting their map?
Old May 5, 2008 | 02:23 PM
00Red_SiR's Avatar
All Motor Mentor
a p30 basemap is for a b16a and you clearly don't have a b16a. A P72 basemap would be a better place to start.
Old May 5, 2008 | 02:47 PM
DarKStaR5's Avatar
Default Re: ignition timing/ tune ?s (00Red_SiR)
Yea i was leaning torwards that one more, and just change the vtec engagement point, and maybe a few other things.
Old May 7, 2008 | 02:03 PM
DarKStaR5's Avatar
anybody else with some suggestions?
jdmb16ef8
10
May 4, 2008 04:47 AM
tianporn
Engine Management and Tuning
Apr 28, 2008 04:32 PM
BB6-213
Aug 24, 2005 07:59 AM
the.hamburglar
Apr 18, 2004 07:49 AM
B16Hatchcx
Jun 2, 2003 08:10 PM
