where is the ecu jumper on 88-89 crx si to set ignition timing!!!!!
Old May 4, 2008 | 02:41 PM
jdmb16ef8's Avatar
Default where is the ecu jumper on 88-89 crx si to set ignition timing!!!!!
hey just like the title says i need to find the jumper to jump the ecu to set ignition timing.... im running a chipped p28 and odb1 step up harness i need help asap pls anyone....
Old May 4, 2008 | 04:32 PM
SIXTY's Avatar
Default Re: where is the ecu jumper on 88-89 crx si to set ignition timing!!!!! (jdmb16ef8)
Underhood, driver side shock tower.
JohnnyEF
Feb 10, 2010 06:09 PM
umair
Oct 16, 2008 10:34 AM
flanker
10
May 23, 2008 09:02 PM
95greenteg
Aug 21, 2007 04:00 PM
Scotty Dosent Know
Feb 24, 2006 11:11 PM
