*Please Vote* - Mount Options
I've been rocking the innovative mounts for a year now. I agree with the shake, on cold *** mornings it tends to make my CD player skip when I start it. You can always swap out the rear mount for an OEM one to reduce the vibration, and just use the innovative for the rest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">I voted for oem mounts.
I cannot stand when i get in a car espically if it's gonna be daily driven and the dash is rattling and everythings vibrating.</TD></TR></TABLE>
knowing my motor is not going anywhere makes me feel a whole lot better,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by italionstallion888 »</TD></TR><TR><TD CLASS="quote">
knowing my motor is not going anywhere makes me feel a whole lot better, </TD></TR></TABLE>
Hey i understand, my engine isn't going anywhere with some good OEM mounts. either
I guess it's all about personal preference.. I daily drive my car, but i will be boosting my b20b soon and i will still use stock mounts..
I've heard good things about ES Inserts.. not all of them cause vibration..
well it says they won't bend under pressure and i just got them in the mail today...you're saying i should save $80 more first to replace new mounts and inserts??
i don't get the point of an insert then if pressure isn't going to be put on them and it'll be on the stock rubber mount? i'm confused
well i just threw the insert in the torn driver's side torque mount and it seems like it's working like a charm execpt for...
MY INTERIOR IS VIBRATING LIKE CRAZY!
anyone have experience with vibrations after one insert in a torque mount?? i thought it would just be if i replaced the rear one
I just put the innovative mounts in my integra. Yeah vibration gets kinda annoying when its cold. Im starting to go through my dash and put in double-sided foam sticky pads to reduce the vibration noise
I am using my stock mounts which are a little tore up with the energy suspension inserts. My car rattles like hell when at Idle. When cruising, its like stock. I only did this because I was low on cash and wanted to drop my new engine in already. I plan on purchasing some Innovative motor mounts and swapping all mine with them.
If you are going to replace mounts, just buy the innovative or hasport. They might rattle a little inside at idle, but so will the motor mount inserts. I didn't think they would either until I actually put them in.
-Justin
-Justin
yea it does rattle like all hell at idle and jsut wanted to make sure it's normal...when i look in my engine bay the motor is still but the reservoirs and everything is shaking and my interior is nuts...
when cruising all is ok...
My friend just put hardrace motor mounts into his car. There is minimal vibration, but it is as solid as my es motor mount inserts.
The hardrace motor mounts are more expensive then inserts, but less than the ha-sport motor mounts.
Just another option to consider.
My opinion:
If this is a DD, get the OE mounts.
If this car see the track, Innovative/Hasport mounts.
When I first did my swap in '01 I got the WS exhaust and was loving how quite and buttery it sounded. I got the bright idea of getting the Hasport street urethane mounts - it totally ruined the driving experience for me. The vibrations were so loud it sounded kinda like I was riding in an airplane. I swapped the L+R mounts out and replaced them with the OE ones and it still annoys me a little, but not nearly as loud.
i know what you're saying but i already replaced the torque mounts(l + r) and they broke within 5,xxx miles....crazy i know...they were put on right and everything
so i don't know what my car is doing but it must want to move
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">i know what you're saying but i already replaced the torque mounts(l + r) and they broke within 5,xxx miles....crazy i know...they were put on right and everything
so i don't know what my car is doing but it must want to move</TD></TR></TABLE>
Damn bro, do you do a lot of crazy hard up and down shifting? Maybe you should get some urethane mounts. The Hasport/Innovative etc. units give a rock solid clutch engagement (as if you didn't know) and they sure as hell will let you know when you're not engaging the clutch correctly
ha no i dont downshift(put in neutral and use brake) and i drive normally...once a week i hit 5-6 rpms and daily never hit more than 4, and only hit 4 when needed...upper motor mount is fine too
so i did put in the energry suspension mounts and clutch engagement is much better-car does not "studder" at all...before the other day it did it all the time in first gear accelerating
