distributor
Old May 4, 2008 | 08:33 AM
vxturbociv's Avatar
Default distributor
i have a '96 civic with a b20 vtec.How can i tell what distributor is on it? Are there any part numbers to look for? I just want to replace the cap, I tried on from a gsr/si and it does not fit.Could it be off an integra ls?
Old May 4, 2008 | 09:28 AM
Targa250R's Avatar
be professional
Default Re: distributor (vxturbociv)
TEC Distributors typically have a "TD" number stamped on one of the mounting legs (i.e. TD-44U or TD-68U for OBD-1 B16, and . It's usually very light and most people can't spot the faint lettering, especially if it's covered in grease and dirt, but it's there. Hitachi distributors aren't numbered this way.
There are only 3 or 4 different distributor caps for OBD-1 and OBD-2 B- and D-series engines. Most late-model internal coil distributors take the 30102-PT2-026 cap. What cap did you try? What head and ECU are you using?
Old May 4, 2008 | 10:36 AM
vxturbociv's Avatar
I tried a cap with standard #jh157, i dont know what head is on it i bought the car from a friend that passed away.it has an aem ems
Old May 4, 2008 | 11:39 AM
Targa250R's Avatar
be professional
The head should have either a PR3 or a P72 stamp on it.
The distributor should be marked. Find the numbers stamped on it.
Old May 4, 2008 | 12:25 PM
vxturbociv's Avatar
Default Re: distributor (Targa250R)
it is a td84u distributor and a p72 head. so it must be a gsr head and dizzy. the guy at the parts store told me the b16a and b18c dizzy were the same, what a dumbass. thanks for the help
Old May 4, 2008 | 12:31 PM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxturbociv &raquo;</TD></TR><TR><TD CLASS="quote">it is a td84u distributor and a p72 head. so it must be a gsr head and dizzy. the guy at the parts store told me the b16a and b18c dizzy were the same, what a dumbass. thanks for the help</TD></TR></TABLE>
gsr distributor
if the dizzy wires colors are kinda pastel its obd1 which is 94-95ish
if the dizzy wires are vivid color its obd2 which is 96-01
Old May 4, 2008 | 12:49 PM
vxturbociv's Avatar
Default Re: distributor (MonkeyMagic)
there is 2 aqua colored wires and some pinkish orange looking wires. so more of the pastel colors i think.
Old May 4, 2008 | 01:03 PM
yeah thats the obd1 gsr. parts from a 94-95 integra gsr should be the correct stuff
ls dizzy wouldn't bolt to your head.
this is a wild card but there was a 93 gsr, but it used a b16 casting head. so it could be completely different.
what it comes down to is if the top radiator hose goes to the front of the head its a 94-01 gsr head, so yours would be a 94-95 dizzy
if the hose goes to the head under the dizzy kinda area its a b16 head.. which could be a 93 gsr, or a 94 del sol vtec. these two heads are the same **** basically, but may use a different cap. idk
but those are the three options you have and you should be able to narrow it down from there
luispizarro25
Sep 24, 2009 03:22 PM
integrawow
May 3, 2008 08:55 PM
