Pulleys
Old May 3, 2008 | 11:52 PM
jccrews90's Avatar
Default Pulleys
hey, if i put an underdriven crank pulley and oversized alternator and p/s pulleys, will they negate each other and not add much horsepower?
Old May 4, 2008 | 08:21 AM
locash's Avatar
Default Re: Pulleys (jccrews90)
I have a better idea, screw the underdrive/overdrive pulleys and spend the money on something else.
Old May 4, 2008 | 08:49 AM
GhostAccord's Avatar
Default Re: Pulleys (locash)
It's your money do what you want but I seem to remember reading that most manufacturers do not recommend running both. It's an ether or type setup. Ether Run the accessory pulleys or the crank pulley.
Old May 4, 2008 | 09:26 AM
jccrews90's Avatar
well, ill descride the set-up.
92 civic (eg)
B16A2 head (and tranny) on B18C1 w/itr pistons
would the crank or accessory pulleys be better?
Old May 4, 2008 | 09:01 PM
p10hlm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">I have a better idea, screw the underdrive/overdrive pulleys and spend the money on something else.
Old May 5, 2008 | 04:44 AM
jccrews90's Avatar
i already have both but im going to return the accessory pulleys and use the crank pulley. thanks for the info ghost
wilkerson05
Mar 16, 2006 01:39 PM
duececoupe2
Feb 28, 2005 08:04 PM
japspecjohn
27
Nov 3, 2003 06:13 AM
TurboTeG4
Sep 30, 2003 08:21 AM
armandotyper
40
Feb 11, 2003 10:27 AM
