New powermaster battery
Old May 3, 2008 | 06:38 PM
Desir Performance's Avatar
Default New powermaster light wieght battery
Has anybody used the new powermaster battery, it might be a replacement for the Odyssey 680 that everybody says cant hold charge. I saw it at jegs for $89.99
here's some specs:
XS Power 12V AGM Battery
13.3 lbs
*Amp/Hour: 21
Max Amps: 900
7.14" L x 3.03" W x 6.59" H
http://www.jegs.com/p/Powermas...10683
Modified by Desir Performance at 1:55 AM 5/4/2008
Modified by Desir Performance at 2:01 AM 5/4/2008
Old May 4, 2008 | 02:57 PM
Default Re: New powermaster light wieght battery (Desir Performance)
bump for any user info
Old May 4, 2008 | 03:04 PM
VisualAutoMotoring's Avatar
We've had issues with the Odyssey 680 on customers cars before. Comes to find out that it wont hold a charge due to the fact that it requires a 14V battery charger. Same with the Braille batteries.
Seen the Powermaster battery used a few times but no feed back here. But we've used a ton of the Stinger SP800 with no problems at all
Brand: Stinger
Condition: New
Battery Type: Dry Cell
Max Peak Discharge: 2400 AMP
5-Second Cranking Output: 925 AMP
Cold Cranking Output: 470 AMP
Nominal Capacity: 30 Ah (C20 rate)
Diminsions: 7.1L x 6.7W x 5.6H
Old May 4, 2008 | 07:22 PM
G2K's Avatar
G2K
Default Re: New powermaster light wieght battery (Hybrid-Performance.com)
Thats XS Power battery looks just like the PC680, it even has a similair model number of D680. Something tells me they might be manufactured by the same company.
Old May 4, 2008 | 07:30 PM
SpeedDreamz.com's Avatar
Default Re: New powermaster light wieght battery (G2K)
looks like the same battery. Stinger-aamp also sell Odyssey made batteries. These batteries require a very hot charger to work.
Old May 4, 2008 | 08:00 PM
cigrafix2's Avatar
I just purchased one! I hope its good! I cant go any bigger than this for a battery so wish me luck! I will report back!
Old May 4, 2008 | 09:11 PM
Default Re: (cigrafix2)
Good luck, did you purchase it with the charger? It claims to have 500cca on some sites, let us know how it turns out.
Old May 5, 2008 | 05:03 AM
Default Re: New powermaster light wieght battery (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">looks like the same battery. Stinger-aamp also sell Odyssey made batteries. These batteries require a very hot charger to work. </TD></TR></TABLE>
We've used the Stinger batteries for quite a while now. A regular charger seems to hold it fine where as the Odyssey and Braille ones we've had here wont.
Rttix1337
10
Jan 20, 2014 03:50 PM
pouponu
Honda Motorcycles
Oct 25, 2007 10:03 AM
lil'ek
Audio / Security / Video
Mar 22, 2006 06:21 AM
turbohondask
Honda Motorcycles
Jul 15, 2003 10:23 PM
