b18a swap-97 civic sedan
Old May 3, 2008 | 05:54 PM
smoothsedan's Avatar
Default b18a swap-97 civic sedan
i need a hydro tranny for this swap correct??
Old May 3, 2008 | 05:56 PM
AGP-EG's Avatar
yessir
anything else you need to know
Old May 3, 2008 | 06:11 PM
Default Re: (AGP-EG)
ecu?? and axels?
Old May 3, 2008 | 06:26 PM
ltrkstr2k's Avatar
Default Re: (smoothsedan)
b-series axles,half shaft and shift linkage. and a Pr4 or P75 ecu are the easiest options.
Old May 3, 2008 | 06:39 PM
Default Re: (ltrkstr2k)
what is the diff between pr4 and p75?
Old May 3, 2008 | 07:05 PM
AGP-EG's Avatar
nothing, other then newer ecu design by a few years, might have slightly better fuel and maps designed into it "possible" but people say there the same and ive had both before there pretty much the same.
A half shaft is also called a intermediate shaft, there is a bunch of names for parts that mean the same thing just to give you a heads up.
The axels are 94-2001 acura integra when you go into a auto parts store to buy them or get some from the junkyard still in ok condition, same for the intermediate shaft, AND T-bracket. The t-bracket is the big black squarish thing behid your transmission underneath the intake manifold that holds the BACK motor mount, you need a 94-2001 T-bracket.
Old May 4, 2008 | 11:04 AM
pr4 OBD0 correct?? this will work
Old May 4, 2008 | 11:50 AM
ltrkstr2k's Avatar
what obd are you planning on running?
Old May 4, 2008 | 01:18 PM
i dunno much about swaps man, i have a 97 honda civic sedan with a d16y7, i picked up a b18a1 for cheap and im having it rebuilt, the year i believe is 90 on that. so my car now is obd2 right?? what do i need for the b18?
Old May 4, 2008 | 01:41 PM
MonkeyMagic's Avatar
dude.. just obd 1 or 2 dizzy and the obd2a computer, or an obd1 computer and jumper along with the usual mounts and ****
this has been over forever and again X 1000000
search... or better yet just click the faq on this forum.
have a beer while your at it
Old May 4, 2008 | 01:46 PM
Default Re: (MonkeyMagic)
well dude....i wasn't satisfied with the info i got from my search, i know where the button is and how to use it, thanks tho, you dont need to post or even read if you dont want too.....
Old May 4, 2008 | 02:07 PM
actually i do
and if you werent satisfied with the info you found, you didn't look hard enough.
EDIT: and i even GAVE the answers to the the only questions you should be asking in my previous post
Old May 4, 2008 | 02:20 PM
obviously not, but i dont know a whole lot about these swaps like i said
Old May 4, 2008 | 09:43 PM
AGP-EG's Avatar
You need a P75 LS B18 ECU, thats OBD2A i believe since your civic is a 97!
Old May 4, 2008 | 09:44 PM
AGP-EG's Avatar
http://cgi.ebay.com/ebaymotors...ZWDVW
Lots of other places you could look like local junkyards, and salvage yards, or online junk/salvage yards.
Modified by AGP-EG at 10:51 PM 5/4/2008
Blackpatch92
Jul 30, 2012 08:57 PM
thresher
Texas -OK -LA (Sales)
11
Jul 8, 2010 12:36 PM
NoLeftTurn
Aug 9, 2006 12:20 AM
speedy13nd
Jul 11, 2006 11:50 AM
runu
May 28, 2003 07:59 PM
