TD-44 vs. TD-68: OBD1 distributor differences?
Old May 3, 2008 | 02:55 PM
integrawow's Avatar
Default TD-44 vs. TD-68: OBD1 distributor differences?
The distributors I was looking at are on Rywire.com. They are both obd1 distributors that fit a b16, and other models. However, the td-68 is more expensive. What's the big difference?
Old May 3, 2008 | 03:19 PM
TrackSpeedRacing's Avatar
Default Re: TD-44 vs. TD-68: OBD1 distributor differences? (integrawow)
The TD68U distributor is the one that the car originally came with (ex: 94-95 Acura Integra GSR models.) However, the TD44U distributor is compatible with the only difference being that the distributor caps ARE NOT interchangeable. Either distributor will work but I guess it comes down to whats currently available.
Old May 3, 2008 | 08:55 PM
slofu's Avatar
the heatsink on which the ICM is mounted on the TD-44 is secured [to the dizzy housing] by screws inside of the cap, whereas screws securing the [different] heatsink of the TD-68 go through the side of the cast housing. no real benefit of either one.
Mugen1320
Jun 28, 2005 08:53 PM
