install a differential ..
Old May 3, 2008 | 02:31 PM
h22civicsedan's Avatar
Default install a differential ..
does neone have a diagram or something that would show me how to install a differential into a non lsd transmission... the tranny im talking bout is one on an h22...
Old May 3, 2008 | 08:04 PM
mymeatb18
Default Re: install a differential .. (h22civicsedan)
go to hondahookup.com and sign up its worth it you can download the whole service manual for your car and others. and you cant really just put in the lsd and thats it you have to make sure it will be shimed correctly otherewise you could have problems
Old May 5, 2008 | 04:05 AM
PSI GUY's Avatar
Default Re: install a differential .. (mymeatb18")
If you are putting a stock H22 lsd that normally comes in an H22 LSD tranny, you will need to replace the clutch housing as well, as they are not the same cases as the transmissions with open differential. OBX can use the stock housing without modification, as well as Quaife.
TH22A1
10
Feb 12, 2010 11:03 PM
h22_crx
Apr 26, 2006 12:04 PM
Kashi
Jan 18, 2005 11:03 AM
GAccord
May 1, 2004 11:52 PM
