WTT 95 hatchback B18B BUILT BOOST
I want a bike like crazy! looking for anything new. i have cash to throw too...
I have had this car for over 2 years now and has been an on going progect and my favorite car. I have a ton of receipts for it and proof of the built motor. Its a stong motor and just needs a tune and some paint. i have put my fair share of money into this car and everything under the hood is fairly new.
Mod List
Car: 1995 Honda Civic SI Hatchback 202k miles NO RUST
Motor: 1997 Acura Integra LS (B18B) 1.5k miles
Tranny: 2000 Acura Integra GSR (B18C) 72k miles
Car Goodies: Sunroof, Power Locks, ORIGINAL QUARTER WITH NO RUST, clean interior, have MT slicks, have a new drivers door
Bad: needs paint and alittle body work, needs tune, needs a hood
Motor: B18b1
~Block~
SRP 8.5:1 forged pistons
JE turbo piston rings (filed and gaped)
JE locks/pins
Eagle H-beam rods
ARP rod bolts
Golden Eagle block guard
ACL Bearings
Polished Crank
Cylinders honed to .005 clearances
Decked .004
Balanced/Blue Printed
Solid B18 swap mounts
~Head~
Crower StgII Cams
Resurfaced
Brand New Honda Head Gasket
ARP Head Studs and Bolts
NGK Plugs
10.2 Wires
Ported Short Ram Intake manifold
Powder Coated VC
Tranny: B18c1
70k miles
ACT SSHD clutch
HCP 5spd conversion mount
GSR Axles
Exhaust:
3 inch down pipe
3 inch flew pipe
3 inch Glass pack
Catless
Fuel/Tuning:
DSM 450s
DSM register box
B&M fuel pressure regulator
Tuned with Crome
Walbro 255 fuel pump
3 bar GM Map sensor
Summit Fuel pressure gauge
Custom high flow fuel rail
Turbo:
Garrett T04305 .70 a/r compressor, .82 a/r turbine, 76 trim
LovFab Ramhorn Turbo Manifold
TIAL 38mm wastegate
26x12x3 FMIC
Polished/bead rolled intercooler piping
TurboXS RFL BOV
Turbologic boost controller (mounted inside)
Blitz Dtt DC-2 metric boost gauge/turbo timer
Autometer boost gauge
Weapon R catch can
Suspension:
KYB Struts
Ground Control Coilovers
DC sports front strut tower bar
Mickey Thompson 24.5x8x15 slicks
Exterior:
STOCK!
Interior:
MOMO Monte Carlo steering wheel
Honda (genuine) shift boot
Sound:
Pioneer head until
JL speakers
Misc:
Engine wire harness tuck
Re-clear coated and painted bay
Block painted Black
Head painted Black
Tranny painted black
Throttle body painted black
Modded bumper/cover for front mount
Maintenance:
Cam Seals
Front Crank Seal
Rear main seal
Clutch slave cylinder
Water pump
Valve cover gasket
Exhaust manifold gasket
Turbo manifold gasket
Wastegate gasket
New starter
New Honda upper/lower radiator houses
Intake manifold gasket
Fram Oil filter
New Honda water hoses
Throttle body gasket
Now the outside! ive got a new door and hood for it and it will be painted in the next 2 weeks!!!
ORIGINAL QUARTERS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i can be contacted at 570-419-7862, AIM on civicb18tkid, or email at rowkan13@pct.edu. Names Kane
Mod List
Motor: B18b1
~Block~
JE locks/pins
Eagle H-beam rods
ARP rod bolts
ACL Bearings
Polished Crank
Decked .004
~Head~
Crower StgII Cams
Resurfaced
NGK Plugs
10.2 Wires
Powder Coated VC
Tranny: B18c1
70k miles
ACT SSHD clutch
GSR Axles
Exhaust:
3 inch down pipe
3 inch flew pipe
3 inch Glass pack
Catless
Fuel/Tuning:
DSM 450s
DSM register box
Tuned with Crome
3 bar GM Map sensor
Turbo:
TIAL 38mm wastegate
26x12x3 FMIC
TurboXS RFL BOV
Weapon R catch can
Suspension:
KYB Struts
Exterior:
STOCK!
Interior:
Sound:
Pioneer head until
JL speakers
Misc:
Block painted Black
Head painted Black
Maintenance:
Cam Seals
Front Crank Seal
Rear main seal
Water pump
Valve cover gasket
Wastegate gasket
New starter
Fram Oil filter
Jo3f1sh
Jul 23, 2009 12:57 PM
civicb18Tkid
Sep 10, 2007 07:56 PM
