94 teggy wont start
1994 Integra Ls
ok i just got done working on the fuel pump and the main relay since i couldnt hear the fuel pump prime but now i do, But i checked to see if there was any spark and nope nothing can i check something else before changing the distrubitor? or maybe i have the sequence wrong can anybody help me?
Modified by r1chst3r at 1:31 PM 5/17/2008
NO it wasnt running when i got it.... when i got it, it was at the mechanic some guy took it to get the timming belt done and the water pump fix they did that so i was driving by and saw the car i ask the mechanic if it was for sale he said yeah i have a mechanic leen on the car just give me 500 for it and take it he said that all i needed was spark plugs and wires since it didnt have any so i brought it home and got that done but couldnt get it to start found out i couldnt hear the fuel pump prime so i changed that and then u told me to check the main relay fixed that (i can hear the fuel pump prime now ) but still i cant get it to start not even jump or push start it
does it even crank over if not i would look at the fuse panel under the hood i know that the car has a fuse for the ignition system you should check that first i know it sounds stupid but it is most of the time the problem that everyone over looks
i would check the ignition control module and th coil
Thnx guys for all the help been a long time since i been here but i got the car running i after yall helped me out i said screw it im just going to change the dizzy and it runs now but now im trying to find a b16 or gsr head i want to go V-Tec
and thnx alot guys for the help this is my second home besides Houston-imports.com
lawlerlaw
Nov 16, 2004 01:25 AM
