91 integra dash question
I'm helping my friend put some gauges ect. in his 91 integra but am having a hard time getting the bezel out. The climate control keeps wanting to come out with the bezel, I took the screws out above the radio and everything, but it's being difficult
pull out all the buttons with a 90 degree pick, disconnect the wiring from them all, pull the ***** off the climate controll and fan speed control, then pull the piece out that is behind the *****, then there is two srews behind that, bottom right there is a small ribbed piece pop it out, one srew there, one behind the coin tray, lower the steering wheel all the way down pop it out! make sure when re installing the pod to hook up the speed cable , it is not stationary, n kinda difficult, so try it n test drive before u put the dash back in ( if u are removing the cluster)
CaliforniaK
Sep 4, 2007 10:05 AM
