ZC tranny fit up to a d16a6???
Old May 2, 2008 | 12:51 PM
Jt'sRex's Avatar
Default ZC tranny fit up to a d16a6???
will ZC tranny fit d16a6???
Old May 2, 2008 | 12:54 PM
Jt'sRex's Avatar
Default Re: ZC tranny fit up to a d16a6??? (Jt'sRex)
also will a pgm fi intake off a zc fit on a d16a6 that has the same set up?
Old May 2, 2008 | 02:22 PM
24TEN's Avatar
PHANTOM MENACE
If you are referring to the SOHC ZC then yes on all accounts. If you are referring to the DOHC ZC, no on the intake manifold. For the tranny, I believe the DOHC ZC tranny uses different axles. The tranny itself will bolt up but the axles are like an integra because it utilizes a half/mid shaft and equal length axles. I don't know if the D16A6 has the provision to mount that half/mid shaft.
Old May 2, 2008 | 03:15 PM
Jt'sRex's Avatar
Default Re: ZC tranny fit up to a d16a6??? (24TEN)
are the throttle bodys the same on the zc dohc and the d16a6?
Old May 2, 2008 | 03:39 PM
kowcain's Avatar
24 ten is correct but as far as the tb's i wouldnt think it would really matter size by about a mm only if anything.
Old May 2, 2008 | 04:02 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jt’sRex &raquo;</TD></TR><TR><TD CLASS="quote">are the throttle bodys the same on the zc dohc and the d16a6?
</TD></TR></TABLE>they are the same, if it is OBD0 DOHC ZC
jetpilot
Oct 23, 2005 08:19 AM
Dwight Schrute
Jun 30, 2004 09:02 PM
d357r0y
15
Jan 25, 2004 03:05 PM
J T*
Nov 3, 2003 11:23 AM
spun Vtec
Jan 15, 2003 11:23 AM
