For those who know body work prices...
if your integra is just black, do it yourself. wetsand the area down until there's no gloss around the scratch, use red lead to fill the spots where there's texture. let it dry. wetsand the red lead until it's as smooth as the surrounding paint. shoot some acura black on that bad boy and wetsand it until it's shiney. it should cost you 30-40 dollars for the supplies. grab your nuts and go. painting is not hard. getting the courage up to try is
. black is the easiest color to paint. good luck. shops will rape your anus to fix that
edit: by integra i mean civic
[Modified by Archidictus, 3:39 PM 7/13/2002]
depends wehre you go, the dealer will charge 500+ but you could probably get a decent job done for 300. considering that my friend just had his whole hatch sprayed and all the dings out for 600, pretty nice job too
