JDM FOG LIGHT HELP!!!
ive searched and couldnt find anything....
my jdm fog lights went out on me... the light on the button went out also so im guessing its a fuse.....
where is the jdm fog light fuse located?
is it located under the fuse box or does the line have its seperate fuse?
please help ASAP. THANKS
Modified by YAH YAH at 8:02 PM 5/4/2008
There's usually a fuse in the wiring harness..
So try to trace the wiring from the foglight harness.. you might need to pull off the front bumper..
If it's not a fuse.. Check your ground &bulbs.
my fiance's did the same thing, I took everything apart, couldn't figure it out, it ended up being the wires coming out the fog light, where the factory heat wrap is, the wires got so hot they melted together and shorted out, so I cut, soldered and connected everything together, have worked perfect for the last 6 months, got a bit brighter to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super jdm yo »</TD></TR><TR><TD CLASS="quote">since you say the light in the button isn't even on anymore, it could be from there also. check the power supply wire to the button. </TD></TR></TABLE>
do you mean the harness? and the plug? i cant seem to find where the wires go to. it routes to under the dash near the fuse box and i cant see anything from there....
6footmidget
Aug 27, 2008 11:29 PM
