Need help picking springs...
What springs would you guys suggest for a very small yet noticeable drop on a 2001 Prelude? I want to improve the handling and the looks without sacrificing driveability.
So overall what would you guys suggest for a nice clean look and better handling without going super low.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m00nr0ck Si »</TD></TR><TR><TD CLASS="quote">Eibach Sportlines....they ride better than stock and give a decent drop for a daily driver....</TD></TR></TABLE>
I'll second that.
I'll second that.
get u a decent set of coilovers. dosent haft 2 be anything like JIC magic that cost a **** load. ive had springs and coilovers, i like my coilovers..
The Eibach Pro-Kit is more of what you are looking for. You might also want to look into the Tein S Tech's. Probably is exactly what you want. Search and you should find many posts about both. I had the Pro-Kit for quite a while and enjoyed it, but you will more than likely need to get camber kits and an alignment. If you aren't ready to do that at the same time, just wait. May as well go ahead and put in fresh struts while you're at it too, most stock struts blow shortly after lowering.
That what i run, Nice stance, Nice ride, Ftw
Once again thanks for the replys. I am looking into the Teins H or S. I have seen sportlines and ridden in them and they are nice, but they might just be a little to low.
Thanks again fellas.
1ntensiveVTECivic
21
Aug 6, 2003 12:48 PM
