Suspension & Brakes Theory, alignment, spring rates....
NEED HELP FOR DA LCA's
Old May 2, 2008 | 12:31 AM
tonysteg541's Avatar
Default NEED HELP FOR DA LCA's
my mechanic said I couldent put my BLOX LCA's on because of the brake line. I guess It bolts on the stock ones and the blox LCA'S dosent have a hole to go thrue to bolt on to! What do u guys think? is he full of it?
Old May 2, 2008 | 06:45 AM
japanjay's Avatar
* B A N N E D *
Default Re: NEED HELP FOR DA LCA's (tonysteg541)
I got skunk 2's on mine and just let mine kinda sit there. Havent had any problems in the last 6 months and check under the car quite often using a lift. Do you have ABS? If I remember correctly the brake lines actually bolted to a ring that was welded onto the shock. I dont have ABS, so if you do, it might be different. I got type 2 coilovers so I had no where to bolt them to.
Old May 2, 2008 | 06:47 AM
japanjay's Avatar
* B A N N E D *
Default Re: NEED HELP FOR DA LCA's (japanjay)
Also I heard that the blox lca's have shitty bushing's and fall apart within a couple of months. I would suggest getting some ES rear LCA bushing and have them press out the old ones and press in the ES and then the blox will be just fine. That way you dont have to take put them on and take them off later and put them back on later.
tonysteg541
May 4, 2008 09:17 AM
uLTrAvTEc757
Sep 1, 2004 02:40 PM
Rob :190:
Sep 15, 2002 06:35 AM
