B16 Running rich. intermitent problem. But mostly a problem.
Old May 1, 2008 | 09:36 PM
MIsterE533's Avatar
Default B16 Running rich. intermitent problem fixed, loose ground. close the thread please?
Finished my b16 swap ran awesome for about 250 miles. I now have a super rich fuel problem. I have an apex AFR guage hooked up, reads 10.0:1 A/F ratio or less. O2 voltage is 1.3-2.0. It might be a loose ground? Any Idea's at all? its a stock b16 with a p28 spec c ecu. This is driving me [freak]ing up the wall. Plugs are perfect runs on 4. Igintion timimg is 16 deg BTDC +/- 2 deg. All in spec. Engine sounds fine cracks vtec nice and hard. All the fluids are full no moisture on Oil cap. No oil leaks all the fun ****. It runs right intermitently, and sometimes the tach and speedo jump. Could i just have a loose connection somewhere?
Modified by MIsterE533 at 10:47 PM 5/1/2008
Modified by MIsterE533 at 8:17 PM 5/2/2008
Old May 2, 2008 | 05:07 AM
MIsterE533's Avatar
Default Re: B16 Running rich. intermitent problem. But mostly a problem. (MIsterE533)
morning up. someone shed some light please?
Old May 2, 2008 | 07:39 AM
wonder squirrel's Avatar
Hows the fuel pressure look?
Might have a bad diaphram in the fuel pressure regulator thats allowing the engine to suck fuel in from there.
Not likly to cause only intermittent problems though.
Old May 2, 2008 | 07:16 PM
MIsterE533's Avatar
fuel pressure is good. i like my fuel pressure guage, its about 30-35, high flow pump. and problem fixed. tell the mod's to close the thread i had a loose ground.
Old May 2, 2008 | 08:04 PM
Former User's Avatar
Out of curiosity, which ground happened to be loose?
Old May 13, 2008 | 08:55 PM
MIsterE533's Avatar
Default Re: B16 Running rich. intermitent problem. But mostly a problem. (RonJ@HT)
my water jacket ground, where your o2 maf and fuel system ground to. only problem with how honda wire's motors and cars, no redundant grounding, easy to find problems, but when you have a problem good luck driving it. im gad we dont play with toyota's where there's a ground every 3 inches on the return side of circuits.
Cshondaman407
Jan 27, 2016 12:43 PM
AzntaggeR
Jul 1, 2005 04:17 AM
MysteryWagon
10
Jul 25, 2003 08:30 AM
SIRBUSH
Oct 15, 2002 02:15 AM
