ENDless Brake Fitment
Old May 1, 2008 | 06:50 PM
triple lobe's Avatar
Default ENDless Brake Fitment
Does anyone know off the top of their head if there is an Endless 6 pot front brake kit that will fit a 99 civic with 16" wheels +42 offset?
If not, what would be the best brake upgrade for the same car?
Thanks.
Old May 15, 2008 | 08:02 AM
log1c's Avatar
Default Re: ENDless Brake Fitment (triple lobe)
a regular 6 pot endless caliper, i highly doubt it
i believe the 6 pot compact mini can fit under the 16s
Old May 27, 2008 | 09:54 PM
Sturmmann's Avatar
Default Re: ENDless Brake Fitment (log1c)
Endless 6 pot compact mini are meant for 16" wheels. But that system will not fit for the 92-00 civic / 94-01 integras. The Endless kit comes with 11.1" rotors for these cars and only a 4 piston kit is available.
You can ask Endless USA if they will be willing to interchange the 6 piston compact mini for that kit. I doubt it because even though the compact 6 has nearly the same dimensions as the 4 piston, it is slightly taller. That's why it calls for 16" wheels.
Your offset of +42 is quite high, you will need at minimum 5mm spacer to clear unless your wheels disk face has ample space. My BBS RG-F needed at least 3mm but I used a 5mm anyways. It had an offset of +35, now it's +30.
vteclolz
Jul 24, 2012 03:01 PM
92SR4WS
Mar 18, 2008 05:19 AM
N4me (06civicsi)
Honda Civic (2006 - 2015)
Aug 14, 2006 02:01 PM
alexb16hb
Jan 7, 2005 04:17 PM
InsertCleverSN
22
Mar 26, 2003 07:49 AM
