Cam Gear help
I was just wondering, what kind of gains can be had from using an aftermarket cam gears in your vehicle? Are the retardation and advance in timing with the aftermarket cam gears something that you wouldn't be able to accomplish w/a stock set?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">well if your talking about hp gains there are none they just allow you or your tuner to adjust timing which you cant do with stock cam gears</TD></TR></TABLE>
There is plenty of HP to be made by dialing in overlap........
and OP no you can't adjust your stock cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaInFaMMuS1 »</TD></TR><TR><TD CLASS="quote">do u mean by overlapping the intake and exhaust valve timing? </TD></TR></TABLE>
yes. Or decreasing it.
