TESTING waters: 97 gsr longblock and MUCH MORE......
Old May 1, 2008 | 11:21 AM
PROJECT 91's Avatar
Default TESTING waters: 97 gsr longblock and MUCH MORE......
services for sale also, let me know what you need done?
need your a/c recharged for this summer?
need a alignment?
clutch slipping?
running on 3 cyl?
let me know what you need done, i have great prices.!!!!
maintence services available also for your non project car (trucks,suvs, and other cars)
i have for sale:
testing waters: 97 gsr longblock with about a good 110k on it with timing belt and waterpump changed at around 92k. good longblock, sitting around just collecting dust and dont have time to do what i wanted to do with it. missing dizzy and harness.: SOLD!!!!!
obd1 gsr dizzy: OFFER please!
91 ls trans w/ 108k: 250
91 s1 trans (miles unknown, used for 10k): 350
93 gsr trans w/ about 80k: 450
92 gsr trans with a hole in trans, gears are been rebuilt, output shaft spins and is a true gsr.: 180 (all you need is a casing and swap out gears and your good to go)
91 ls longblock, missing dizzy, wired for obd1 but have obd0 harness also depending what you want to do with it. new head gasket, waterpump, timing belt. all installed and never dropped in. 108k on motor: 350
DA air box (box only w/ filter): 10
blue DA seatbelts: 20
black DA e-brake cover: 5
92 ls head w. bare intake manifold: 100
92 ls block with everything, sensors and all to the oil pan (great for build): 100
DA rad. needs draincock, 50, only 3000 miles on it: 50
si throttle cable, ls throttle cable, gsr throttle cable, sohc throttle cable,: 10 bucks each
cut obd2 gsr harness: 10
DA driver kick panel, missing coin tray but have a switch for whatever you want: 5
spare tires. 13s and 14s: 10 for 13s and 20 for 14s
9 lb exedy lightweight flywheel: 120
big spline b-series clutch, pressure plate by exedy and disc should be exedy but doesnt say. lots of meat left on disc: 120
brackets gallore: what everybracket you might want i might have!!! ask for bracket and get a price, CHEAP!
94 ls A/C compressor, great condition, will install and have your a/c charged for extra: 70 for compressor and 200 with it installed and charged
94 ls PS pump, greeat cond: 30
94 LS PS pump bracket, great for swaps: 10
cable s1 trans gears, most of it, cheap!: 60 bucks for everything i have
96 civic stock struts, 40k miles on i, no signs at all of leaking: 40 bucks
a/c lines from 94 teg, which on do you need? LMK
tein springs of a DA: 70
auto meter boost gauge and oil pressure gauge with dual pod: 100
88-91 ef civic rack and pinion, perfect for DA non-ps: 100 BNIB
DC a/c condensor: 25
DA bent shift linkage (one piece bent): 5
DA driver side motor mount w/ bracket: 50
DA rear T-bracket: 25
obd1 PR4 chipped by dinan (dont no the specs, was given to me): 120
obd1 PR4 (virgin): 75
99-00 civic sedan rear LCAs (stock): 25
will be updated, still lots of misc things i have.
thanks for looking!!!!
-Bobby
Modified by PROJECT 91 at 6:12 PM 5/1/2008
Modified by PROJECT 91 at 6:49 PM 5/3/2008
Modified by PROJECT 91 at 9:59 AM 5/8/2008
Old May 1, 2008 | 08:08 PM
RShatchy's Avatar
Default Re: TESTING waters: 97 gsr longblock and MUCH MORE...... (PROJECT 91)
nice. ill be interested in the ls longblock with the tranny
Old May 1, 2008 | 08:45 PM
PROJECT 91's Avatar
Default Re: TESTING waters: 97 gsr longblock and MUCH MORE...... (RShatchy)
just let me know!
also have a red 92 DA shell for sale!
Old May 3, 2008 | 05:49 PM
PROJECT 91's Avatar
TTT
Old May 6, 2008 | 09:08 PM
RShatchy's Avatar
bump
Old May 6, 2008 | 11:45 PM
sickeswrx's Avatar
how much for ac recharge? thanks
Old May 8, 2008 | 12:50 AM
spoonhatchblack's Avatar
Default Re: TESTING waters: 97 gsr longblock and MUCH MORE...... (sickeswrx)
PM price for the gsr longblock?
Old May 8, 2008 | 08:57 AM
PROJECT 91's Avatar
PMs replied to, and the gsr longblock was SOLD tuesday for 1000
kodylive
Sep 24, 2012 04:37 PM
jdmbeegee
Sep 6, 2006 12:13 AM
teg4life
Feb 2, 2005 09:07 PM
conceptEG
Sep 5, 2003 10:24 AM
