Where can i find a hub?
Old May 1, 2008 | 08:58 AM
hondamn1320's Avatar
Default Where can i find a hub?
i've searched and couldn't find any thread that can tell me where to find a hub for my B16 swapped DX hatchback.
i'd like to get this part new. so please leave junkyards out of this.
does anyone know the honda part number i would need? i need a hub from a CRX or Civic SI correct? none of my local parts stores carry this part, and it's rather annoying driving down the street with the loud grinding noise.
is there any other place other than honda that i can aquire this part from, new?
thanks for any and all help.
and just to be clear, i need the part where the rotor and wheel mount to. i've seen it refered to as a spindle also, which is why i am clarifying what it is i need. thanks.
Old May 1, 2008 | 09:40 AM
wiZCo's Avatar
Stouts 'n' Scotch
Just get a stock hub for a DX or Si.
Honda P/N: 44600-SH1-A00
If they don't have it locally, order from http://www.hondapartsdeals.com or http://www.hondaautomotiveparts.com
Old May 1, 2008 | 04:06 PM
Big red89's Avatar
Bought mine off ebay. Came in and fit perfect.
Mines a civic dx 89
Old May 2, 2008 | 04:52 AM
Default Re: (Big red89)
thanks a lot. so the hub from a DX will work with an SI wheel bearing? or are they the same thing?
Old May 2, 2008 | 06:32 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (hondamn1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamn1320 &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot. so the hub from a DX will work with an SI wheel bearing? or are they the same thing?</TD></TR></TABLE>
Yes and yes.
Old May 2, 2008 | 07:51 AM
Default Re: (wiZCo)
thanks...
one more question. :D
will DA knuckles fit on an EF? talking about knuckles, hub, and whatever else i'd have to swap over to work.
Old May 2, 2008 | 08:09 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamn1320 &raquo;</TD></TR><TR><TD CLASS="quote">thanks...
will DA knuckles fit on an EF? talking about knuckles, hub, and whatever else i'd have to swap over to work.</TD></TR></TABLE>
Yes they do fit, just use your stock UCA's (upper control arms). This is a perfect upgrade for your EF, bigger brakes are always a plus!
Old May 2, 2008 | 08:50 AM
GI8U2racing's Avatar
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Yes they do fit, just use your stock UCA's (upper control arms). This is a perfect upgrade for your EF, bigger brakes are always a plus! </TD></TR></TABLE>
The legendary 90-91 Civic EX knuckles and brakes are always the best option...if you can find them
Old May 2, 2008 | 08:53 AM
CRX Toad's Avatar
Default Re: (GI8U2racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">
The legendary 90-91 Civic EX knuckles and brakes are always the best option...if you can find them</TD></TR></TABLE>
Actually we have all three stock (CRX/CRX Si/Civic DX/Si), EX and DA and have found there to be no difference. And CRX/CRX Si/Civic DX/Si/EX axles will fit all three just fine.
I was tired of the misconception so we measured it all.
https://honda-tech.com/zerothread/2140287
And if anyone needs any schooling on the booster's/mc's I know that too
https://honda-tech.com/zerothread/1508680
Old May 2, 2008 | 09:29 AM
Default Re: (CRX Toad)
thanks a lot everyone. awesome help.
petr0lb0mb
Transmission & Drivetrain
Oct 26, 2014 07:42 AM
braass91
Oct 19, 2012 09:28 PM
lunareg
Nov 10, 2010 08:42 AM
Bravenrace
Aug 20, 2008 08:41 AM
fastlimegreencivic
Oct 24, 2007 11:06 PM
