How much vacume? (bigger cam guys)
Old May 1, 2008 | 06:57 AM
Running925's Avatar
Default How much vacume? (bigger cam guys)
Hey guys. Just looking in general to get some input on what kinda vacume you guys are pulling at idle with bigger cams.
NOT: gsr cams / itr cams, i'm looking strickly for aftermarket numbers.
Old May 1, 2008 | 11:04 AM
IN VTEC's Avatar
Default Re: How much vacume? (Running925)
About 20"Hg to high 19"Hg with Skunk2 Pro2+'s.
Old May 1, 2008 | 11:14 AM
ChampWhiteTegra's Avatar
Default Re: How much vacume? (IN VTEC)
18ish with crower 402t's
Old May 1, 2008 | 11:51 AM
p0gi's Avatar
Default Re: How much vacume? (ChampWhiteTegra)
Around 20" on comp 57200
Old May 1, 2008 | 12:05 PM
DaveF's Avatar
Default Re: How much vacume? (p0gi)
8-10"
Old May 2, 2008 | 06:53 AM
Running925's Avatar
ok so maybe mine isn't that bad. I was so used to my old ls motor with stock cams pullin like 20.. When i saw my gauge readin 15-16 i thought it was odd & figured it had to be something with my cams.
I don't have any vacume leaks, i've checked everything over real well to assure my self of that. I've got a set of custom ground cams in here that are compairable to some skunk2 stage 2 NA cams.
I'm wondering if i advance the exhaust cam gear a degree or so, to remove the overlap, if that might give me a little more vacume. any thoughts on this?
the whole reason i'm getting at this subject is because my tial bov isn't opening like it used to due to the change in vacume.. i might just have to order a spring but figured if i can make an adjustment to compensate then i could save my self the hastle & money of ordering & replacing the spring.
*EDIT: Cam Spec's
Intake: 0.485, 252
Exhaust: 0.466, 262
Modified by Running925 at 8:40 AM 5/2/2008
abusedvtec
Jul 3, 2010 10:00 AM
VTIargentina
May 29, 2010 07:54 PM
Dasanib20T
Jul 6, 2008 11:44 PM
rough_draft
Aug 22, 2004 12:00 PM
singlecam screamer
Dec 24, 2002 10:23 AM
