Suspension & Brakes Theory, alignment, spring rates....
92-95 coilovers on 96-00
Old May 1, 2008 | 04:55 AM
cimo463's Avatar
Default 92-95 coilovers on 96-00
So I have a stock 97 civic 4 door and i was given a set of H&R full coilovers for a 92-95 civic. Will this application work on my car? I know lots of parts swap over from each generation and I just want to know if this will work.
Old May 1, 2008 | 02:58 PM
cimo463's Avatar
Default Re: 92-95 coilovers on 96-00 (cimo463)
anyone?
Old May 1, 2008 | 05:40 PM
98vsmhatch's Avatar
Fronts are direct swap. The rear LCA Mount is Wider than EK chassis so you will need to throw in some washers/spacers to close the gap.
Old May 3, 2008 | 02:39 PM
cimo463's Avatar
Default Re: (98vsmhatch)
Sweet...thanks man
Old May 4, 2008 | 07:17 AM
team1320_k26eg's Avatar
Default Re: (cimo463)
we swapped a jic suspension for a eg to a ek with no problem so you should be straight.
Black Diamond
Mar 23, 2021 12:06 PM
The Collin
Jan 18, 2007 06:56 PM
mr0lg
Mar 2, 2004 06:27 AM
heel_touge
Jan 30, 2004 06:56 AM
