Transmission parts interchange
Old May 1, 2008 | 04:46 AM
PSI GUY's Avatar
Default Transmission parts interchange
I have a 92 GSR tranny that the third gear sleeve and hub is destroyed, i priced the part and its $270, the part number is 23442-PS1-N00, which is also the same part number as the third gear sleeve set in a 93-97 Delsol Vtec, but not the same part number as the 99-2000 Civic Si.
The only thing is the sleeve set for the 99-2000 SI is a $100 cheaper, but im pretty sure i have used parts from one to the other, just can't remember if the hub is the same diameter and i don't have one here to compare. Part number on the 2000 SI sleeve set is 23623-P21-315.
Anyone have any insight here, i searched but couldn't find anything on this.
Thanks
Old May 2, 2008 | 05:32 PM
PSI GUY's Avatar
Default Re: Transmission parts interchange (PSI GUY)
still looking for information, if someone even had some parts they could compare kicking around that would be great
Old May 5, 2008 | 08:32 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
for some reason, acura sell 3/4 sleeve set with either 3rd or 4th gear. you can't buy just the sleeve/hub/synchros/synchro springs. honda sells the entire synchro assembly without a gear...hence cheaper. and del sol b16 and 99-00 si are all the same part as well as for your 92-93 gsr. they may have different part numbers but are interchangeable.
ej_b16a
Transmission & Drivetrain
Sep 1, 2010 09:27 AM
tekstyle
Sep 2, 2007 11:36 PM
Super Chicken
May 3, 2007 05:22 PM
01-0720
Jun 2, 2005 01:53 PM
