Quick OBD1 conversion jumper question...
Old May 1, 2008 | 01:06 AM
bobjohnson's Avatar
Default Quick OBD1 conversion jumper question...
Ive got a SOHC vtec ZC, originally ran OBD1 i assume. I want to run it OBD1 in my car now, because its running rich and generally not running as well as id like.
My question is, if i want to convert it to OBD1, if i buy the jumper harness to plug the OBD1 ECU in, do i need to do anything else, wiring wise? I already know i need to run the wires for the 4 wire O2, and theres some wiring with the OBD1 distributor as well, but will i need to wire anything else under the hood besides those 2 things? Or will the jumper harness take care of all that? I cant really find any explanation, and i checked the rywire site but they dont really explain in a lot of detail exactly what the jumper harness does. I see mention of a chassis harness, and theyre saying you can send your engine harness to them and have it wired... do i really need to do that? Im comfortable enough to wire up the O2 and distributor myself.
Old May 1, 2008 | 04:33 AM
Disco Monkey's Avatar
Default Re: Quick OBD1 conversion jumper question... (bobjohnson)
you have to do some wiring with an obd1 jumper harness.
http://www.boomslang.us/obd0_1.pdf
Old May 1, 2008 | 05:29 AM
dem0nk1d's Avatar
rewire the dizzy, and add a 92-95 4 wire o2 sensor. everything else should be fine.
Old May 1, 2008 | 07:38 PM
bobjohnson's Avatar
Default Re: Quick OBD1 conversion jumper question... (Disco Monkey)
Thats thats exactly the information i was looking for.
That boomslang PDF is really helpful. Maybe i will order their conversion harness.
zapzach
19
Feb 24, 2012 10:35 AM
mahatma
Jun 4, 2006 07:30 AM
Novtecdohc
Aug 18, 2005 06:32 PM
soundman
10
Nov 14, 2003 07:59 PM
