MY REX JURKS WEN I SHIFT
Old Apr 30, 2008 | 10:10 PM
rexie's Avatar
Default MY REX JURKS WEN I SHIFT
I HAVE A 91 CRX AND WEN I SHIFT FROM FIRST TO SECOND THE CAR JURKS KIND OF LIKE MOVING FOWERD LIKE IF I WAS AT A HIGH RPM AND WAS PUNCHING IT AND LETING IT GO I KIND OF CANT EXPLANE IT ANY IDEAS
Old Apr 30, 2008 | 10:49 PM
DCFerris's Avatar
i have this same problem open up your hood look behind the motor where your transmission connects to the crossmember and see if the mount is still connected to the crossmember. Mine riped off the crossmember i hear its not that rare
Old Apr 30, 2008 | 10:53 PM
burnout8488's Avatar
Default Re: MY REX JURKS WEN I SHIFT (rexie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexie &raquo;</TD></TR><TR><TD CLASS="quote">ANY IDEAS</TD></TR></TABLE>
1) Turn off caps lock
2) Check for torn mounts, or even disconnected mounts like DCFerris said. If you're still rocking the stock motor, you've got 4 mounts to check. One at 12, 3, 6, and 9 o'clock if you're looking at the engine and pretending there is a clock on it.
3) Report back with findings.
Old Apr 30, 2008 | 10:56 PM
bobjohnson's Avatar
Default Re: MY REX JURKS WEN I SHIFT (burnout8488)
Man, my advice would have been learn how to shift. My car does it if i pop the clutch shifting from first to second (or neutral to first). The other gears are way more forgiving but 1st to 2nd is not.
I learned to drive stick on a crx and it did it all the time. After i learned how to use the clutch, it doesnt happen anymore.
Old May 1, 2008 | 09:26 AM
draperj09's Avatar
Default Re: MY REX JURKS WEN I SHIFT (bobjohnson)
Probably motor mounts. Does your motor raise excessively when shifting?
Old May 1, 2008 | 09:36 AM
wiZCo's Avatar
Stouts 'n' Scotch
Turn the caps lock off!
As said before, it could be a clutch problem, the way you're using the clutch, or a bad mount.
Old May 1, 2008 | 10:08 PM
rexie's Avatar
Default Re: (wiZCo)
SORRY IT TOOK ME SO LONG TO UPDATE U GUYS WELL I KNOW ITS NOT MY DRIVING BECAUSE I HAVE TWO CRXS AND THIS IS THE ONLY ONE THAT DOES IT BUT I DO HAVE A Q WAT ARE THE CAPS AND ILL ALSO CHEACK THE MOUNTS WEN MY BRO COMES HOME WITH THE CAR
Old May 1, 2008 | 10:17 PM
EFHATCHMAN's Avatar
Default Re: (rexie)
CAPS LOCK... its a button on the keyboard your typing on right now!!!
Turn that sh*t off!!!
Old May 1, 2008 | 10:19 PM
2slow4stock's Avatar
Wow... The caps are on the keyboard... Look next to "A" and to the left of it says "Caps Lock" ......
Might be motor mount then.
Caps lock off please...
Old May 1, 2008 | 11:22 PM
bobjohnson's Avatar
Default Re: (rexie)
If your clutch is completely worn it might acting more like an on off switch rather than something that has any variability. If it jerks once its probably mounts, if it jerks back and forth really fast (which from your desciption i think is whats happening) its the clutch not making good contact.
It doesnt matter how long youve been driving or how many CRX's youve driven, my roommate has only ever driven stick and even he had my car bucking like a horse on speed trying to go from first to second until he learned how to "finesse" my blown clutch.
I got it replaced and now you almost cant do it even if you try. If you pop the clutch at low revs without touching the gas you can still get it to give a couple little jerks though.
Old May 3, 2008 | 12:59 PM
jrscb16eg6's Avatar
Default Re: (bobjohnson)
torque steer.. i have perfect mounys by hasport and my car does it. it just takes gettting some use to
Old May 3, 2008 | 07:23 PM
zcmotor's Avatar
mines stutters....i dont have a mount where the tranny goes... where it holds to the cross member you guys think that could make it stutter ?
Old May 4, 2008 | 10:59 PM
mario_pic's Avatar
Default Re: (zcmotor)
lol i put new mounts on my ef and thay tore the front after a week i was like WTF lol mine moves a lot i got a 99 y8 in mine with full hydro conversion it moves like crazy but pulls nice only hits cross member in reverse
Old May 4, 2008 | 11:08 PM
DCFerris's Avatar
yeah i have that i have been looking to see if they had after market ones link the front but they dont just got to find a good welder lol
Old May 4, 2008 | 11:49 PM
zcmotor's Avatar
Default Re: (mario_pic)
i need the motor mounts but i dont think that's what causing the stuttering on my car. usually when im stopped and start going it cuts off for a sec and it goes back into speed.
Old May 9, 2008 | 10:06 PM
DCFerris's Avatar
is it stuttering like its idle is to low or what is that the case adjust you idle bolt
jestin91
13
Dec 13, 2012 04:43 PM
showcivic2001
Sep 17, 2008 05:06 AM
s4yama
May 24, 2008 10:24 PM
civicSIracer96
19
Dec 11, 2003 09:24 AM
kahren
19
Dec 16, 2001 09:14 AM
