Questions about hub centric wheel spacers & hub centric rings.
Old Apr 30, 2008 | 09:45 PM
ZC88CRX's Avatar
Default Questions about hub centric wheel spacers & hub centric rings.
Who makes hubcentric spacers for hondas that both space the wheels out (5mm in my case) but also center the wheel to the hub/spacer?
Or am i overcomplicating things?
Can I slap a 5mm spacer on, then add my plastic hub centric ring to that?
Thanks guys!
Old May 1, 2008 | 06:33 AM
ZC88CRX's Avatar
Default Re: Questions about hub centric wheel spacers & hub centric rings. (ZC88CRX)
Beuler?
Old May 1, 2008 | 12:10 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC88CRX &raquo;</TD></TR><TR><TD CLASS="quote">Who makes hubcentric spacers for hondas that both space the wheels out (5mm in my case) but also center the wheel to the hub/spacer?
Can I slap a 5mm spacer on, then add my plastic hub centric ring to that?</TD></TR></TABLE>
Hubcentric spacers are also known as wheel adapters and look like this:
However, I've never heard of any in thicknesses less than 15 mm. For 5 mm, you're probably only looking at thin, flat spacers, which don't have the lip and thus are not hubcentric.
And no, hubcentric rings won't help. The idea behind hubcentric rings is to reduce the too-large center bore (big hole in the middle of the wheel) to the diameter that just fits around the hub. If you're using a 5 mm spacer, it pushes the wheel out past the hub, so there's nothing for the hubcentric ring to fit around.
AztecEGhatch
Oct 5, 2013 09:24 AM
AdRoz
Sep 6, 2007 10:50 AM
YoungKadafi
Suspension & Brakes
Mar 10, 2007 05:06 PM
navin
Dec 9, 2004 04:54 PM
RAB
14
Sep 19, 2002 04:45 PM
