tranny just went out...
Old Apr 30, 2008 | 07:03 PM
darkblackH2B's Avatar
Default tranny just went out...
I need a new tranny in my h2b 92'. Its got a hydro b16 tranny right now, just wondering if i can replace it without changing anything else if i got something other than a b16. gsr? ls? itr? would i need to change out the axles out? thanks helpp!
Old Apr 30, 2008 | 07:05 PM
z6hatchboy's Avatar
Default Re: tranny just went out... (darkblackH2B)
I dont think you'll have to change the axles with any of those trannys
Old Apr 30, 2008 | 07:09 PM
Default Re: tranny just went out... (z6hatchboy)
so would any of those work just the same as the one i had for the most part? just put it on and im good?
Old May 1, 2008 | 07:18 AM
Bump need serious help fellas!
Old May 1, 2008 | 07:38 AM
ek4_b16a's Avatar
are you sure it is the trans that went out? it could just be your clutch...check and make sure before you do something huge like that...gl
Old May 1, 2008 | 08:59 AM
Default Re: tranny just went out... (ek4_b16a)
yes took it to a shop, to reasure, differential is shot, etc.
Old May 1, 2008 | 09:28 AM
cherroneballs's Avatar
You could just change te differential, get a quaife or something. and yes if you get another b sereis in there all your axles linkages ect. are the same.
90civicstdgold
May 8, 2009 07:10 AM
1bar_ek
May 18, 2008 04:44 PM
SonicRacing
Mar 6, 2006 11:21 AM
GHETTOassREX
May 27, 2004 05:32 PM
